No picture in ch manager select both Ant A & Ant B but still no picture
Adjusted mag mount antenna w/a swr meter. When checked it w/the meter on the '06 uniden pc78 elite, ch 40 was a lot higher. Which is correct ?
The coax jumpers between the meter and the radio can change the SWR a little bit. It is very unlikely the the antenna can be that low on 1 and 40. Set it for the lowest on 20 via the radio and as long as you are under a 2 on 1 and 40 then it should be OK.
Oct 10, 2016 | Uniden Radio Communications
No sound
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | CH Products CH Gamecard 3 Auto (300-053)...
I have great sound on my tv but there is no picture
i had the same problem take the back off an unplug the lcd an give it a blow put bit all back together an fany's your ant
Apr 24, 2010 | Sanyo DP37647 37 in. LCD TV
Tv/video mode with no remote
you should have a menu button on the
frount of the tv press it and then select
with the (ch up) (ch dn) to highlight the
input/sorce or ant select with the enter
button then (ch up ) ( ch dn) highlight
video 1 or 2 press enter .
If this was not helpful tell me the
model # and look it up on my data base.
Sep 21, 2009 | Microsoft Xbox 360 Console
My tv just started to look like if I didn't have cable it has a breeze
must be off channel, if using cable box make sure its on ch 3, also check Ant switch on remote if two ant inputs
Aug 28, 2009 | Maxent MX-42XM11 Television
I do not have remote 2 year old threw it down heating vent. I have universal remote but really does nothing. TV is set to aucun signal YPbPr1. When I push imput I see the choices and have tried each...
Press input repatley until you get to (ant 1)
or (ant 2) then press the chanel up/down to
get to ch 3 make sure the converter box is
conected to ant input.
Jun 24, 2009 | Televison & Video
Key for microsoft office picture manager 2003
I think you should purchase the key. Picture manager isn't part of the MS Office suite and it sounds like your trial has ended.
Sorry for the inconvenience,
Feb 26, 2009 | Microsoft Office Professional 2007 Full...
Panasonic tv
- push menu
-ant cable
-sleep 30 min
-ch 124
-vol min with remote
-press vol - in front tv
- aparece chk you see
-with button poweer select
- push pwr & action to exit
Sep 12, 2008 | Panasonic CT-27SL15 27" TV
Want acer e-(net management ant sount management) for aspire4520 for winxp
By giving you the following link, I do not in any way, shape or manner reccomend this website or product. It is your responsibility if you obtain a trojan/virus, etc.
Although, it is the official website.....
Select your region and follow the steps.
Aug 01, 2008 | Acer Aspire 5050-3242 Notebook
Snowy picture
A snowy video indicates that your input signal is relatively weak. On the other hand, a noisy picture is when there are too much interference is super imposing on the video.
Snowy picture comes about when the signal coming in the RF INput (Ant/Cable) at the back of the unit is below a certain level. If this is the case, then it is not a problem with your TV but rather your aerial (antenna) or the cable from your provider. A way to verify that it is the ant/cable that is the cause and not a defective TV/tuner is to hook up an old VCR set to Ch. 3 or 4 to the RF IN of your TV using a short 75 ohms coaxial cable terminated at both ends with FP-5 connector. Play a known clear good tape and set your TV to Ch. 3 or 4 as the case maybe. If the picture is relatively clearer, better, then you have just confirmed that it is indeed your aerial or your cable (provider) that needs looking into. If on the other hand, the VCR signal is also snowy then chances are that you have a problem with the input stage of your TV including possibly your tuner.
For your aerial problem, antenna orientation or replacing with a higher gain antenna might help solve the snowy signal. For your cable problem, you have to call-in for service from your cable provider. If it is a TV problem, your best course would be to seek the services of a qualified TV technician since this involve electronic circuitry analysis, diagnosis and possible component replacements.
Additionally, you may try looking for any loose connection, loose grounding, broken wire or anything out of the ordinary in your connections.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 12, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
