Question about Retail Supplies
Beverage air drink cooler poss mr145 or mr39 metal plate with #0105987 the original label badly worn.
Need to find service/parts manual
  • 331 Answers
SOURCE: bev air cooler
Bill, the main reason I've noticed for higher than normal temps in these boxes is filthy condenser coils (this will affect pressures in your sealed system). Remove the front lower panel and inspect your coils. Use a coil brush or a dust broom to thoroughly clean them up, don't use water. You can also pick up some condenser coil cleaner in a spray can from your local appliance parts store, but it's not necessary (the fumes are strong and may be objectionable to your customers... it gets 'em really clean, though!) After cleaning the coils, allow 24 hours for temps to stabilize. If they don't, here is a site for Beverage-Air, contact your local servicer with you exact model and serial number for pressure specifications. Hope this helps! Let us know, will ya?
Posted on Aug 13, 2007
  • 86 Answers
SOURCE: fan in cooler copartment runs constantly
Its normal
Posted on May 27, 2008
  • 828 Answers
SOURCE: Cooler`s Spare Parts
Coca Cola does not manufacture these coolers. They are manufactured by another company for Coca Cola. Model number MT45 is a "Beverage Air" product.
Some parts for these units can be ordered through a company called "Case Parts" that are on the internet.
Posted on Jul 31, 2008
  • 358 Answers
SOURCE: freezing up TD-64-24 beverage cooler
Some of this TRUE don't have service valves, but you can put a tapping valve (A1) in the appendix (small piece of pipe comming out of the compresor and seal on the other end).To check the pressure you need to know what type of refrigerant is in the system .If is 134a the low side should be about 24psi and the high around 160 it could vary depends how hot is inside the place and the fridge but not much more than 200.If you working with R22 pressures be around 60 low and 250 high side.
Posted on May 01, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Where can I get a wiring diagram for an
If it's the condenser fan you are talking about you will not need a wiring diagram. The fan should be wired to the compressor and the thermostat. the thermostat is the relay to start the fans and compressor. I will continue to look for a wiring diagram. When the fan wears out they will stop causing the cooler to overheat. I think replacing the fan would be what you need. I believe that Beverage Air used the Copeland compressor with the condenser fan mounted on the one end of the the same slide in compressor. Check your voltage on the 2 wires going to the fan. When compressor is on the fan should also be running. I just have the feeling that condenser fan is defective.
Sea Breeze
Posted on Aug 19, 2009
Can I use my wine cooler to store other beverages?
The average wine cooler won't offer temperature below 46 Fahrenheit. Due to this fact you can store most of the light beverages in it but it is not meant to store this kind of drink. I suggest you to purchase a mini refrigerator in order to store your other drinks.
Aug 14, 2012 | Furniture
What does the overload relay look like a Beverage-Air MT27 Beverage Cooler Commercial
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Sep 27, 2011 | Beverage-Air MT27 Beverage Cooler...
Need to see if evap fans r working
this site has your manual and the manual has wiring diagram.
also has some common trouble shooting questions and answers.
Jul 06, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
We have a Coldtech Beverage Cooler that doesn't seem to be keeping the drinks as cold as it did? Possible problem?
Dirty condenser coils will compromise cooling. Do a good hoovering around the coils and make sure the condenser fan motor air flow is not restricted.
Jun 28, 2010 | Coldtech J1GR-24L Beverage Cooler
The condenser motor is a 9W
The evap motor is 503-088B
Get your parts at
Mar 11, 2009 | Beverage-Air MT45 Beverage Cooler...
Need part number
I am pretty certain that Beverage Air is owned by Sanyo.
Take a look at their website and see what you find.
But isn't the light holder just a standard florescent or other type of bulb holder?
Jan 29, 2009 | Beverage-Air MT45 Beverage Cooler...
Jul 30, 2008 | Beverage-Air Refrigerators
The inside is hot
A couple of consequences to a dirty condenser. First the compressor could have blown a valve. Second the cap tube and/or liquid line drier could have clogged - If the unit has R-134A this is more common than not.
Of course there is also the possiblity that the dirty condenser had little to do with the original service call and that the unit is low on refrigerant or has a faulty thermostat.
Jun 10, 2008 | True GDM-9 Beverage Cooler
Retail Supplies Logo
Top Retail Supplies Experts
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
