Question about Beko Dishwashers
We are trying to replace a door handle on a beko dishwasher DSFN 1530B. We cannot remove the programme panel all screws have been removed and we are stuck. Can you advise
    Top Expert:
  • 867 Answers
Before you can remove the top panel you have to remove the front outer door panel, there are screws down the sides to remove it.
Posted on May 15, 2017
Dishwasher door handle
Remove the screws around the inside of the stainless steel door panel, once you can gain access, repair or replace the door handle and return the door panel to normal.
May 05, 2016 | LG Dishwashers
I have a loose door handle. what tools do I need to repair it and how?
Depends on the brand and type of handle. I'll give you a few general ideas. The first easy one is to look under both ends of the handle for small set screws. If you see them, a small allen wrench should tighten the set screws and the handle. The next type requires the removal of either the inner door panel or outer panel. Some dishwashers will have screws along the inner edge of the door panel. you remove the screws and either the inner panel will come loose or the outer panel will come off (depends on make and model) Once the door is apart you should be able to see the handle screws to tighten. Some doors also have a screw in both bottom corners facing upward that may need removed . Best I can do at this time.
Apr 03, 2015 | Dishwashers
How do I adjust the door hinge tension on a Beko Dishwasher DW51
Hello!
most dishwashers have springs on each side of the door bottom that can be moved to different mount points to adjust tension.
In many cases they may be accessed by removing the bottom kick panel, but it may be necessary to back off the from adjuster legs, remove any other cabinet securing screws and pull the unit out slightly.
All the best.
Nov 20, 2014 | Beko Dishwashers
On Off switch faulty
The switch is available from eSpares.
http://www.espares.co.uk/product/es1624719/onoff-switch?ModelId=1630729
The rear of the control panel will become accessible by removing the screws holding the stainless steel door panel from inside the door. Make sure the dishwasher is disconnected from the mains power supply.
Mar 30, 2014 | Beko Dishwashers
How do I replace the rubber door seal on my beko wmb71642w?
This video will show you in detail how to replace the door seal gasket and fit the new one properly to beko wmb71642w washing machine How to Replace Beko washing Machine Door Seal
Oct 17, 2013 | Beko Genuine Washing Machine Door Gasket...
Beko dsfn 1532 start button will not stay down
We have the same problem. How did you resolve this issue?
Dec 30, 2012 | Beko Dishwashers
I have a Maytag MDB6600AWW that is giving me a fit. It only works when it wants and the door is hard to operate as the handle isn't connected correctly anymore.
It could be your lid switch.
If the door handle is brocken the lid switch is not making contact properly.
Ash
Oct 21, 2009 | Dishwashers
Broken handle on dishwasher
Bernie,
TURN OFF POWER TO UNIT. Open door, remove all torq screws from door panel, separate inner and outer door panel. latch assy is able to be removed, place black wire connector and white white connector back respectively, place inner part of door back and replace the torq screws. Then turn power back on for unit.
Jan 09, 2009 | Maytag Dishwashers
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Door handle
removing the front panel is just meccano. the screws are probably torex - a driver is easily available from any tool shop
Mar 24, 2007 | Gaggenau GI936-760 Dishwasher
Dishwashers Logo
67 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
