Question about The Health & Beauty
I have a new meter but it won't work. I've checked the battery and cleaned contacts, but it does not respond when I insert a test strip.
Accu-chek acctive model GU GU05543715
2 Suggested Answers
computus
  • 487 Answers
SOURCE: Cannot perform set-up for Accu-Chek Performa
Hi, yes sorry but you will need to purchase new strips.
Posted on Jul 05, 2010
My accu-check performa blood glucose meter is not working It shows E-1 on the screen.How do i reset it
The E-1 error usually indicates that the test strip is damaged or improperly inserted. Try removing the test strip and replacing it. Try a different test strip. Open a new box of test strips and try using one from the new box.
I hope this helps. You can find the manual for the Accu-Chek Performa on the product page: https://www.accu-chek.com.au/meter-systems/performa . The direct link to the manual is currently https://www.accu-chek.com.au/download/file/fid/16491 . The error messages and trouble-shooting are to the right-hand side of the page. You will need to scroll a bit.
Feb 24, 2018 | The Health & Beauty
Accu chek blood glucose meter error 3 and error 6
E3 is the following
Your blood glucose may be extremely high or a meter or a test strip error has occurred.
  • If your test result matches how you feel, contact your healthcare professional immediately.
  • If your test result does not match how you feel, repeat the blood glucose test.
    • If the E-3 code still appears for your blood glucose test, your blood glucose result may be extremely high and above the system's reading range. Contact your healthcare professional immediately.
    • If the second test result does not match how you feel, perform a control test with the control solution and a new test strip.
      • If the control result is within the acceptable range, review the proper testing procedure and repeat the blood glucose test with a new test strip.
    E6 is the following
    • Blood or control solution was applied to the test strip before the flashing drop symbol appeared on the display. Discard the test strip and repeat the blood glucose or control test.
https://www.accu-chek.ca/en/meter-systems/aviva/support-error-screens
Feb 13, 2018 | Accu Chek Health & Beauty
I wails like to download a accu-check mobile user manual
User Manual - Accu-Chek
https://www.accu-chek.ca/en/download/file/fid/11461
Therefore, follow these instructions carefully to perform a blood glucose test .... The Accu-Chek Mobile meter may only be used by one and the same person for ...
ACCU-CHEK MOBILE USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > ... > Blood Glucose Meter > Mobile View and Download Accu-Chek Mobile user manual online. Mobile Blood Glucose Meter pdf manual download.
Replacing The Cassette - Accu-chek Mobile User Manual [Page 205]
https://www.manualslib.com > ... > Blood Glucose Meter > Mobile > User manual Accu-Chek Mobile Manual Online: Replacing The Cassette. or or Replacing the test cassette 12 1 Place your finger on the corrugated area on the tip cover and...
[PDF]User's Manual for Single Patient Use Only - Accu-Chek
https://www.accu-chek.com/download/file/fid/14766 User's Manual, follow your healthcare professional's instructions, or contact your ...... automatically synchronize your diabetes information with a mobile device ...
Accu-Chek Mobile - How it works - YouTube
? 2:12
https://www.youtube.com/watch?v=bpJpm2RqdGE Apr 14, 2010 - Uploaded by AccuChekUK
A blood glucose meter for people with diabetes. Makes monitoring your blood glucose fast and easy, with an ...
Accu Chek Mobile - Video Guide, Meter Review and Fastclix Guide
www.diabetes.co.uk > Blood Glucose Care > Blood Glucose Meters The Accu-Chek Mobile was first introduced in 2010 and provided users with the chance to take a blood test without needing to hold a set of additional loose ...
accu chek mobile user manual Google Search
Sep 27, 2017 | Cell Phones
What is a E-1 code for an ACCU-CHEK meter?
"E-1" in the display means the test strip may be damaged or the code key is incorrect. Remove and reinsert the test strip.
Jun 29, 2017 | Health & Beauty
What does E-7 mean?on my accu chek meter after inserting strip with blood?
It can mean one of a couple of things:
~An error occurred, when this happens you should turn it off, reset the unit, and turn it back on after at least 20 seconds have passed. You can also remove the battery and put it back in if you don't want to reset the meter
~You need to run a control test with control solution to realign the machine
~You inserted a used test strip or faulty test strip into the meter, try another strip
Mar 24, 2017 | Accu Chek Health & Beauty
Meter shows E9 on inserting test strip?
E9 means that the battery needs to be replaced
May 30, 2015 | Accu Chek ACCU-CHEK Aviva Meter
Please tell me what the code E-5 means. It shows up on my accu-chek compact plus meter
The information you need is in the reference guide for your meter.
The reference guide can be downloaded from
https://www.accu-chek.co.uk/gb/products/metersystems/compactplusgt.html > Related Products
if you have the blue/silver front version (and probably also if you have black version) of the meter, E-5 means
"The measurement optics are dirty or you
have inserted a test strip that has already
been used or is too old. Clean the
measurement optics (Chapter 7.1) and
repeat the test with a new Accu-Chek
Active Glucose test strip."
17.January.2015
17.January.2015111
Jan 16, 2015 | Accu Check Accu-chek Safe-t-pro Plus...
What are the error codes for Accu-Check Glucometers
E5 codekey expired which means that the test strips or out of date and no longer any good. You get a new codekey with a new can of test strips. A pain, I know.
E1 Re Insert test strip
E2 Incorrect code key
E3 Extremely high reading
E4 Not enough blood on test strip
E6 Control Solution too soon?
E7 Electronic error
E8 Temperature too high
E9 Change Battery.
May 13, 2014 | Accu Chek ACCU-CHEK Aviva Meter
Health & Beauty Logo
22 people viewed this question
Top The Health & Beauty Experts
trinatiodel
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
