ALARM CODE TABLE FOR AIR CONDITIONING SINOMA MODEL LF28N MAKE CHINA
2 Suggested Answers
SOURCE: sanyo air conditioning alarm PO4 fault what does i...
High presheer on out door unit.faulty presheer switch or condenser is blocked :)
Posted on Mar 26, 2012
Error code E6
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.If your need any other air conditioning help check out Air Conditioning Repair Tamarac we will be sure to answer any question you have
Jul 28, 2016 | Heating & Cooling
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
Air conditioning works but when switched to heat it does nothing and gives a he code
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Also what is the error code so we at West Palm Beach Air Conditioning can give you a hand.
Oct 16, 2015 | Heating & Cooling
My unit show a code error E1 the model is lp0910wnryo
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 07, 2011 | Heating & Cooling
The letters EI are flashing and I cannot find my manual to see what it means model # SAC8400D
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
heatman101
Aug 30, 2010 | Heating & Cooling
I have a Haier model # HWR10XC5-T - what does the E-1 error mean?
http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
heatman101
Aug 17, 2010 | Haier HWR10XC5 Air Conditioner
Sanyo air conditioning alarm PO4 fault what does it mean
May 18, 2010 | Computers & Internet
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Air conditioning AND security system questions
I don't know about the alarm issue - having one of those myself. But for the air conditioning - it sounds to me like it needs to be recharged. They can do that at most service station/oil change places.
Jul 17, 2009 | 1998 Volkswagen Jetta
94 thunderbird code 1505
Diagnostic Trouble Code (DTC) P1505 indicates the IAC system has reached the adaptive clip.
Possible causes:
  • Air leaks.
  • Plugged air filter element.
  • Throttle body/linkage binding.
  • Contaminated or damaged IAC valve assembly.
  • Damaged throttle body
The Adaptive Idle Air Control (IAC) strategy is designed to adjust the IAC calibration to correct for wear and aging of components. When engine conditions meet the adaptive strategy learning requirement, the strategy monitors the engine and determines the values required for ideal idle calibration. The adaptive strategy stores these values in a table for reference. This table is used by the PCM as a correction factor when controlling idle speed. The adaptive idle table is stored in Keep Alive Memory (KAM) and retains the learned values even after the engine is shut off. A Diagnostic Trouble Code (DTC) is output to indicate that the adaptive IAC strategy has reached its learning limits.
Whenever an IAC component is replaced or cleaned or a service affecting idle is performed, it is recommended that KAM be cleared. This is necessary so the idle strategy does not use the previously learned adaptive values.
To clear KAM, refer to PCM Reset in Section 2. It is important to note that erasing DTCs with a scan tool does not reset the adaptive idle table.
Once KAM has been reset, the engine must idle for fifteen minutes (actual time varies between strategies) to learn new adaptive values. Idle quality will improve as the strategy adapts. Adaptation occurs in four separate modes. The modes are transmission select in neutral with air conditioning on; transmission select in neutral with air conditioning off; transmission select in drive with air conditioning on; and transmission select in drive with air conditioning off.
Jul 01, 2009 | 1998 Ford Explorer
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
