Question about GE Washing Machines
GE washer not draining
I have a GE WSSH300G Front load washer. It drains ok first load, but then not again until next day. Thinking its the filter I heard about, but can not figure out how to remove front. do I have a removable front kickplate on this machine?
It's not the filter....my washer would not drain too, and I called in GE service (within my warranty). The guy pulled out socks from the pump. Unscrew the front, lift it, then open that pump up (not easy as I watched). He took out the socks, and then the water drained quick and my washer spins like new. He showed a gap between the drum and the rubber seal that was just big enough to have socks or underwears slide through. The likely cause is when the washer shakes while on high spin....hope that helps all of those who's washer can't drain.
Posted on Oct 13, 2009
    President:
  • 1,273 Answers
You should have one. Get down low, and look at the kickplate. You should see screws just below the main front panel of the machine.
best regards, --W/D--
Posted on Jul 25, 2009
GE WSSH300G Front Load Washer drains, but won't spin. Repairman wanted $340 to replace a door latch. ???
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
May 25, 2011 | General Electric WSSH300G Front Load...
GENERAL ELECTRIC WSSH300G FRONT LOAD WASHER PUMP KEEPS RUNNING AFTER DRAINING WATER PRYER TO FINAL SPIN. WASHER WON'T SPIN.
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 10, 2011 | General Electric WSSH300G Front Load...
My machine is not draining properly GE WSSH300G0WW front load washer
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Take care.
Jan 10, 2011 | General Electric WSSH300G Front Load...
GE WSSH300G0WW will drain the water, but not strt the spinning. Is there a filter that might need cleaning?
Yes, the filter can be accessed by removing lower front panel. Unscrew pump cover filter. Have a shallow pan and towels to catch water when servicing
Oct 11, 2009 | General Electric WSSH300G Front Load...
WATER WON'T DRAIN
Check the drain line , maybe plugged with a sock or drain line could be kinked
Jul 25, 2009 | General Electric WSSH300G Front Load...
GE WSSH300 stops after wash and need to hit start again to finish
Be sure to rule out one of the simplest things first---be sure the button that gets depressed when you close the lid is still functioning (or even THERE) Sometimes, if you have had a severly offset load, this switch can become damaged. Some washers will not continue to advance if it " thinks" the door is opened.
May 09, 2009 | General Electric WSSH300G Front Load...
The spin cycle will not work. I think the drain is clogged and would like to figure out how to unclog the drain
If you unscrew the bottom front kick plate there is a black rubber piece to the right in front. In order to get to the filter make sure the washer has no water in it or it will spill all over the floor. The black rubber piece houses the filter. You need a phillips screwdriver to unscrew the clamp at the top of the black rubber piece. Once that is unscrewed you can pull it down and you'll see a white plastic filter inside. It is most likely clogged so it won't drain. When it is cleared it will work again. It is pretty easy but can be messy if there is water still in the drum. Just make sure that you put the rubber gasket back on with the clamp tightened.
May 02, 2009 | General Electric WSSH300G Front Load...
Washer pauses itself
My name is joyce
Are you using He deturgent?
If not this is the problem.
to remove the suds from the pump now you will have to put one tsp of oil in where you put powders at and run cycle on normal and then see what you get. if this dont work let me know and we will go from their.
thanks,
joyce
Feb 05, 2009 | General Electric WSSH300G Front Load...
Washer will not drain
ck pump for obstruction ..remove front by pressing clips along top edge with putty knife front will lift off pump lower right side
Jul 19, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
282 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
