What is .625 in inches - Televison & Video
What would be the approximate ampre hours of and weight of an average five hundred cold cranks 12 volt car battery.
A lot depends on make and construction, but here is a good place to start.
Super Start Fleet & Heavy Duty - Battery
Line: SSB ' Part # 3ET
Jun 08, 2016 | Cars & Trucks
Can't get my 21 1 ir/uhf pro remote to work with dish network dvr 625
If you are attempting to program it to tv-2 on a 625 receiver it has to be set to a odd number for example number 7 instead of 2 or 6.
The reason for this is that the 625 receiver only supports band A frequencies for UHF and on a 21.x remote odd numbers are A band and even numbers are B band.
Sep 25, 2013 | DISH Network DVR-625 DTV Receiver /...
My TI84 plus silver edition calculator is giving me an incorrect sign whenever I do an exponential function. When I type in -25^2, it gives me -625 instead of 625. How do I fix this?
It's giving you the correct answer. It's calculating the negative of 25 squared. 25 squared is 625, and the negative of that is -625.
If you want to calculate the square of negative 25, you need to tell the calculator that.
Press ( (-) 2 5 ) ^ 2 ENTER .
Sep 05, 2011 | Texas Instruments Office Equipment &...
How do I get closed captioning on my 625 dish dvr.
The 625 receiver does not have a setting to control closed caption. This is a setting from your TV itself. I would look at your TV manual to see how you can turn the feature on. I hope this helps.
Ray Calo
DISH Network
May 19, 2010 | DISH Network DVR-625 DTV Receiver /...
What is the ring end gap for the 2003 LC4 625 motor?
.004" per inch of bore. So, .016"
*Help me out. Rate me!
May 21, 2010 | 2003 KTM 625 SXC
Where is the oil drain plug for a poulan self propelled 22 inch 625 series mower
remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Sep 27, 2009 | Poulan Pro " Pro" Self Propelled Mower
How do I open port 30000 in a DIR-625 router?
Hello marquitos4,
Go to
and you will find all the info you need regarding port forwarding through your D-Link router.
The page is specific to the DIR-625 but just about any make/model is supported at
Dec 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
