Question about Hotpoint Washing Machines
I have a Hotpoint Ultima WMD740 and never had a problem with it. I used it two days ago and thought the machine had finished (it was right at the end of the cycle and gives two beeps when finished).
Went to use it today and everything is fine with the programming but it will not start the programme. I think it has something to do with me stopping the machine before it finished its programming but can't figure out how to rectify this....Any ideas please The clock starts the countdown for the cycle but nothing is happening.
gittos73
  • 244 Answers
SOURCE: Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Posted on Aug 23, 2007
reddyanantha
  • 205 Answers
SOURCE: Hotpoint WT960 Ultima 7 kg. The programme seems
there might be loose connection in the programmer please check it.
Posted on Aug 18, 2009
SOURCE: annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Posted on Sep 12, 2009
sudel
  • 90 Answers
SOURCE: Hotpoint WMF540 will not start. Lights keep
Had this same problem myself. To get mine to start i have to push the door to until it starts.
Posted on Mar 07, 2010
  • 2841 Answers
SOURCE: Odyssey battery problem?
You need to remove the battery cables and clean the connections with a wire battery terminal cleaning tool. Then start the car and check the voltage at the battery with a multimeter. It should be between 13.5-16 volts. Any less and the alternator is defective. If this all checks out and you are 100% sure nothing is on drawing power then the battery more than likely has a dead cell. Remove the battery and take it to your parts store and have it tested. You will probably need a new battery.
Posted on Apr 19, 2010
Testimonial: "Very helpful response - thanks so much!"
Hotpoint wmd740 ultima wont rinse and key symbol is stuck also foreign langue has appeared .
unplug the unit for 5 minutes then plug back in.
let me know what happens.
Jan 08, 2018 | Hotpoint Washing Machines
Hotpoint Ultima WD860 Washer Dryer not rinsing properly. Leaves white residue on dark clothes.
quit using powered detergent .we quit many years ago as it does not dissolve properly in our hard water .no problems with liquid .
Oct 16, 2015 | Hotpoint Ultima WF860 Front Load Washer
My washer is French how do I change it back to English
1. Turn the power on at the wall socket.
2. Select ON/OFF at the console so that there is nothing showing in the display - ie: machine OFF.
3. Press & hold the 2nd, 3rd and 4th function buttons until the machine BEEPS (approx. 5 seconds). (centre 3 buttons below the display).
4. Select ON/OFF at the console to turn the machine ON so that the display is ON - it should now show language options scrolling through.
5. Wait until the language you want is shown or scroll through them manually using Spin Speed or Temperature then press Child Lock to select it.
Hope this helps
Mar 18, 2015 | Hotpoint Washing Machines
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
My washer is stuck on f/o5 with water sstill init is a hotpoint ultima super silent
there is a blockage. to get the water out put the end of the drain hose into a basin lower than the machine. you may have to shake it about a bit to get the water flowing.
you will need to check the filter or pump for foreign objects.
these may be at the front behind the kick plate or the rear behind the lower panel.
Feb 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
