WELCOME IHAVE ONE QUESTION FOR SINOMA AIR CONDITIONING UNIT MODEL LF7N.LF12N ----- DISPLAY... ,MAKE CHINA
4 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: American Standard Air conditioning unit Model 2AGB0036A1000AB
Hi I am sure this model number is correct and it is a 3 Ton unit.Normally when the breaker trips as soon as you reset it, the compressor is compromised. Happened to me yesterday on a 5 ton heat-pump. When this happens, what you can do if you are a handy type of man, is to prove this. I don't know if the is is a split system or a all in one package unit, doesn't matter. Get to the compressor compartment. Of course the power will be off.If you can see the run capacitor, take a screw driver and short across the terminals to discharge it, as it could have a small amount of juice in it, I doubt it. Anyway, remove the plastic cover to expose the terminals. They can be hard to remove sometimes, just use a screw driver to push the clips in. Wire colors should be black for common, yellow for start, and blue for run. Write down the order they were in. To be safe, tape the metal connectors so they wont touch metal when you turn the power back on. After you have done this, turn everything back on. If the breaker holds and everything else is on, fan and so on, this proves the compressor is probably shorted to ground. If this a/c is rather new, I would replace the compressor. If it is old, I would think about getting prices on a new unit. Just food for thought. Please let me know on the out come of this test, please. When a compressor shorts out, or locks up, it draws what is called locked rotor amps/LRA which could be from 49 on up, and your breaker can be 25, 30, 35 to 40 amps so it will trip. Keep me posted and do this test, it is very easy to do.
Sincerely,
Shastalaker7
Posted on Apr 18, 2010
  • 79 Answers
SOURCE: Reacharging air conditioning unit
On suction line near the compressor
Posted on Jun 26, 2010
  • 586 Answers
SOURCE: Carrier Air conditioning (Model #39CKC036340.
Hello there,
It does not need a new condensing unit. The reason the breaker keeps tripping is due to the power regultion within the unit of the ir conditioner. If there is a surge in power, the breaker trips. If the voltage is not high enough to be able to carry the full power of the air conditioner, the breaker will be tripping off.
I will advice you try to use it with a step down or a step up, depending on the kind of voltage that was written for it to be using. Check the back for the voltage it works with and try to regulate the current to that using either the step down or step up, depending on the volt and current being supplied to it.
Why should you fix such for $3300, thats too exorbitant.
Hope this helps. Goodluck Elect_Comp
Posted on Aug 28, 2011
I NEED THE YEAR OF THIS MODEL AIR CONDITIONER MODEL #A7D16E2A
Who is the manufacturer of the air conditioning unit? If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 12, 2017 | Heating & Cooling
Zamil ac display showing e5 what problem brand old
What is the model of your air conditioner. With out that information i cant help you with your ac repair problem. If you are having prolonged air conditioning check out Air Conditioning Tamarac for more HVAC Support.
Jul 26, 2016 | Heating & Cooling
Zamil ac display showing e5 what program?
The ac unit will not turn on. The "comp" red light is on & it beeps
Did you get a manual with this unit? I believe the red light is a ground circuit fault interrupter GFCI. This detects minute amounts of leakage current and opens to protect the user from a shock. Is there a drain located on the unit for the moisture that is naturally condensed out of the air you are conditioning? If so, that needs to be drained. Many of the GFCI's they place on these units are cheap as they are made in China. I believe your unit takes some or all of the condensed moisture and runs it over the condensor coil to cool the coil, which is OK. My question is where does the excess moisture end up and how does this unit get rid of it? I believe they sell these at Wal Mart so I know it was made in China.
Aug 03, 2011 | Sunpentown WA-1220E Portable Air...
After spraying off the unit the display shows e1
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 12, 2011 | Haier ESA3125 Wall/Window Air Conditioner
What symbol is for air conditioning?
Here is the operating manual
www.fujitsugeneral.com/.../OwnersManuals/OPManCeilingSuspended.pdf
On Page EN 7 it has the operating instructions for the hand held remote unit. When the word "cool" appears in the display, depending on the temperature that the room is and what the remote is set for, the unit will function in the air conditioning mode.
Nov 28, 2010 | Fujitsu 36CS Air Conditioner
Problem with the Air conditioning unit 2005 toyota avensis
if its cold at 1 location all the time its probably got its gas maybe theres a vent not opening or a duct that has come adrift under dash,if its not cold in general you may need to get an AC guy to look at the fault but keep looking if you think something is simple to fix
Aug 16, 2009 | 2005 Toyota Avalon
Compaq presario c700 laptop
Go here...
http://welcome.hp.com/country/us/en/support.html
and input your model number then download the drivers.
Mar 05, 2008 | Computers & Internet
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
