Question about Coffee Makers & Espresso Machines
After I put the pod into the holder it does not dispense the water
4 Suggested Answers
  • 3 Answers
SOURCE: Francis Francis X1
Some leaking from the group head of the machine is totally normal while the machine is heating. The reason for this is that the valve that sits above the shower screen is simply a spring and rubber ball. The spring expands, creating a seal with the rubber ball and the boiler, once the boiler reaches a specific temperature. Until the boiler temp is reached, leaking from the group head will occur.
Posted on Jul 14, 2008
  • 1618 Answers
SOURCE: water leaks
try inserting the portafilter a little farther in group if it passes 90° then you will have to replace the group seal.
Posted on May 20, 2009
  • 15935 Answers
SOURCE: kenmore front load washer soap dispenser does not
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Water does not drain from dispenser into tub/drum fast enough
pull out the dispenser,check inside where the dispenser goes into,i found in two washers the white circle piece that's inside the cap to detergent,when water would go in the cap would block the fill tube,if you checked the dispenser and water flows through you have something blocking the fill tube,hopefully the washer and dryer are not stacked,you might have to take the top lid off to get at the fill tube or fill hose to clear it.good luck with your washer
Dec 25, 2014 | Washing Machines
Need a descaler
instractions are from manual HD7810/00
Use the correct descaling agent
Only citric acid-based descalers are suitable for descaling the SENSEO
machine. This
type of descaler descales the machine without damaging it. For the correct amount,
see under 'Descaling procedure' below. Each descaling mixture can be used only once.
After use, the descaling mixture is no longer active.
We advise you to use the special SENSEO
Descaler (HD7012/HD7011/HD7006).
Read the instructions on the package of the descaling agent.
Never use a descaling agent based on mineral acids such as sulphuric acid,
hydrochloric acid, sulphamic acid and acetic acid (e.g. vinegar). These descaling
agents may damage your SENSEO
coffee machine.
Descaling procedure
1 Mix 50 grams of citric acid with 1 litre of water in a measuring jug. Stir until
the powder is completely dissolved.
2 Fill the water reservoir up to the MAX indication with the descaler mixture.
Then put the water reservoir back into the coffee machine. (Fig. 3)
Note: Not all SENSEO
machine types have a water reservoir with a capacity of
1 litre. If you have a SENSEO
machine with a smaller water reservoir, repeat steps
2 to 6 with the remainder of the mixture without filling the water reservoir up to
the MAX indication.
3 Press on/off button 3. (Fig. 10)
The machine is ready for use when the indicator light lights up continuously.
4 Place the 1-cup holder h with a used coffee pod in it in the coffee machine.
Close the lid and make sure it is properly locked.
Note: Always put a used coffee pod in the pod holder when you descale the
machine. This pod serves as a 'filter' to prevent the sieve or hole in the pod holder
from getting clogged with scale residue.
5 Put a bowl with a capacity of at least 1500ml under the spout to collect the
descaling mixture (Fig. 8).
6 Press the 2-cup button hhand let the machine operate. Repeat this until
the water reservoir is empty. (Fig. 25)
Never interrupt the descaling process!
7 Repeat steps 1 to 6. Replace the used pod with another used pod to filter out
the scale residue.
Note: To descale properly, you have to use 2 litres of descaling mixture.
Never descale the SENSEO
coffee machine with the lid open. Make sure the lid is
properly locked.
8 Rinse the water reservoir with tap water. Fill the water reservoir up to the
MAX indication with tap water and repeat steps 3 to 6.
Note: Do not refill the water reservoir with used hot water or the used descaling
9 Fill the water reservoir with fresh tap water up to the MAX indication again
and repeat steps 3 to 6 once more.
Note: Always rinse the machine by letting it empty two full water reservoirs.
10 Remove the used pad and clean the pod holder after descaling to prevent the
sieve or hole in the centre from getting clogged.
Mar 30, 2014 | Philips Senseo HD-7810 Coffee Maker
Soap dispenser overflowing with water
You will have to pull the dispenser tray out and clear any debris. I've seen a sock in one (who knows how that got there,) toys and even a glob of laundry detergent pods leavings.
Dec 21, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
My senseo machine doesn't seem to produce the crema layers even though i've followed all the instruction
You may find that the plastic disc on the bottom of the pod holder is not sealing (there is an O ring) ,if the amount of coffee dispensed is more than usual that will be the problem,just buy a new pod holder.
Oct 06, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Stuck senseo maker
The locks shut due to a pressure build up in the pod chamber usually caused by a blocked filter in the centre of the pod holder.
The only way to open the unit is to releive the pressure. The pressure will normally reduce over time, the duration being determined by the pressure build up, condition of pod seals and the strength of the blockage.
A quick DIY solution: (small cable tie and screwdriver required)
Un plug the unit from the mains:
Remove the water container and prise open the rear snap fit panel of the unit carefully using a screwdriver to expose the internal workings, the overflow pipe at the top of the cover must be disconnected to gain enough access to work on the unit.
.The small metal boiler in the centre of the unit is used to heat the water for the machine, if the boiler is still hot allow it to cool down sufficiently for work to commence.
The exit pipe at the top of the boiler feeds directly to the pod chamber, if you squeeze this pipe you will feel that it is under pressure. Cut the cable tie connecting the pipe to the boiler (be careful, dont cut the pipe) and remove the pipe to release the pressure, a small ammount of water will be released during the procedure. The lid should open.
Reconnect the pipe to the boiler replace the cable tie, refit the rear cover making sure to push the overflow pipe back on before you snap the cover shut.
Remove the pod holder and clear the blockage blow through the holder in the reverse direction to ensure the filter is clear.
Replace the pod holder and pour a small amount of water on to it. The water should exit through the delivery spouts if the path is clear.
JOB Done.
Oct 28, 2007 | Philips Senseo HD-7810 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
