Question about Samsung Computers & Internet
I can not hear sound in Samsung syncmaster 400pxn. I checked the sound on the computer and the unit and everything is on high volume? Help
  • 319 Answers
SOURCE: volume high but no sound only a very low static sound
Make sure the unit is not swiched to tape monitor. Check to see if all inputs and outputs are wired properly. Unplug unit and let it sit unpowered for a half hour to reset micro-processor which may have locked up. When you power it up again, listen for click of speaker relays. Make sure to turn volume down BEFORE you power up. If none of these work, take unit to pro tech for check up. It just might be a simple fix, cheaper than replacement. Good luck.
Posted on Apr 12, 2008
SOURCE: No sound on my Samsung Syncmaster 920lm Monitor
This seems to be easy.
1) Your monitor will need to be connected to the sound output using a separate cable, unless it uses HDMI cabling.
2) If that doesn't help, check the sound output using headphones or a different speaker system.
Check it out and post your response here.
Posted on Oct 09, 2008
SOURCE: samsung syncmaster t200 volume
there are no speakers on it, how could u take sound?
Posted on Nov 01, 2008
  • 225 Answers
SOURCE: scratching sound from earphones at high volumes
Sounds like the beginnings of a rubbing voice coil in your MX160. Verify this by trying another set of headphones on your amplifier/MP3 player/etc. If the "scratching" sound disappears then your music source is not the fault. PLEASE REMEMBER...never turn music source volumes up past 60-65% (think of 1:00-1:30 on a clock face). If these setting are not loud enough, use a booster or move up to a unit with more audio output power. On a larger scale...How did I blow my 100 watt speakers with a 50 watt amp? It's easy....clip (overdrive) your amp....Glen
Posted on Apr 07, 2009
  • 30 Answers
SOURCE: whenever i try to play a tune on my phone i dont hear a sound. I tried changing my phone settings volume and i still cant hear anything. Any ideas on what i can do?
i dont know if this helps at all, but you should try to use a earpiece.
Posted on Apr 20, 2009
I am not getting any sound from my new monitor
Check if the driver is working properly and if you have selected the specific device in your audio settings in control panel.
Sep 02, 2017 | Samsung B2230 LCD Monitor
My new samsung 400pxn wont turn on it just keeps on making a continues clicking noise every 2 to 3 seconds and the power lights flicks on and off
This tv still under warrenty?Call Samsung for service.Ur tv the power supply board is dead.That the board where the power a/c cord plug into it.That is ur tv power supply board and is dead.It must require replacing.Tries websites like, to buy a refurbish power supply board for the replacemnt,if the tv is out of warrenty.
Jun 17, 2010 | Samsung SyncMaster 400PXN LCD TV
Hi, I have a Samsung SyncMaster215tw, I've been using speakers to hear music and movies but recently gave them away, how can i get sound directly from the monitor?
The manual (you can download it here if you need a copy) shows an audio input jack right next to the VGA input connector. This jack takes a 1/8-inch stereo plug the same as the output jack on the computer. You can use the same cable that is usually supplied with computer speakers. Just plug the cable into the computer's sound output jack and the monitor input. I'd recommend setting the volume on the computer to maximum, and using the monitor volume control to adjust your sound.
Apr 01, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
No Sound. We moved the computer and now no sound.
Try checking to see to make sure that the audio jacks are plugged into the right ports. Also, check to make sure that nothing is muted, and that volume is up ( I've actually went for sound without a day after moving my computer because I forgot I had muted and turned my volume all the way down the day before xD )
Anyway, I hope this helps, and let me know if it doesn't.
Oh, and one last thing, make sure that your speakers are set as the primary output devices. If you have 3rd party audio drivers, sometimes you have to set what audio output is going through.
Oct 17, 2009 | Samsung SyncMaster 172 W 17" LCD Monitor
Very low sound
hi first format ur operating system. and install sound driver properly. u can also check ur headphone. if any problem headphone change it.
Jul 21, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
your high voltage power supply in the monitor is probably failing.
you will need to take it to a service center.
Apr 18, 2009 | Computers & Internet
Samsung syncmaster t200 volume
Oct 21, 2008 | Samsung SyncMaster T200 LCD Monitor
No power but fuse ok
IF it is making a clicking noise it is the SUB PSU , the one that powers the embedded PC, there are 2 CAPACITORS on the PCB that will be domed at the top a 1000uf and 1500uf, they are on the secondary side , this is a common problem with this and the 460PXN (same psu) replace caps with higher voltage rating is my advice,!!! I did everything OK!!
Apr 25, 2008 | Samsung SyncMaster 400PXN LCD TV
No sound when on pc mode
Check if your PC can play audio on some other speakers or headphone. If yes, check your monitor audio cable connections. If no something's wrong with your PC audio drivers. Try re-installing them or could be a hardware issue with your PC. Get it checked.
Sep 29, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Computers & Internet Logo
44 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
