Question about Luxor Televison & Video
My luxor tv has no sound and when I press volume controls a picture of a headphone appears. I have no headphones in and the tv just switched to this mode. How do I get sound back?
likha
  • 790 Answers
SOURCE: Sound Problem
ok paola! the problem is the headphone connector inside the TV.. maybe did not turn back the switch to speaker mode. check the headphone connector (at inside the tv). small problem goodluck paola!!!
Posted on Sep 14, 2007
  • 3 Answers
SOURCE: headphone jack is weird...
HAVE YOU TRIED THE BEST QUALITY HEADPHONES LIKE SONY AND DID YOU CHECK YOUR COMPUTERS VOLUME?
Posted on Mar 27, 2008
SOURCE: no sound through the headphones
The way the headphone jack works is:
plug your headphones in and then mute the television using the remote.
While the TV is muted you can still use the volume up and down controls to adjust the volume through the headphones. I find that having the volume at 60-75% is more than loud enough on the headphones.
Just be careful when you unplug the headphones and take the TV off of mute, if your volume levels are still turned up you will be in for a jolt :)
Posted on Feb 01, 2009
  • 20 Answers
SOURCE: No sound from the TV when the headphones are plugged in.
if you have a stereo unit(am+fm reciever) that has output to speakers, connect the out jack of the tv to input on back of stereo unit(aux in or cd input) then you can have output to headphone and speakers also.
Posted on Apr 07, 2009
SOURCE: Not able to increse volume.The volume controller on my laptop automatically slides down even if I increase it while using the headphone.
your head phone volume controller /speaker/s has been short circuited so please replace /purchase new headphone
thank you
Posted on May 24, 2009
I have bought a pair of Sony wireless MDR-RF810RK, and after five to ten minutes of listening ,the transmission fails and the light switches off. If I switch on again it recommences for some...
Hello!
I must inform you that most of the wireless headphones has an automatic shut-off which puts it in stand-by when there is no sound going in to it. Or if the sounds in your device is too quiet the headphones will think you have finished using it.
What you need to do is increase the volume setting of your device. And turn the volume control on the headphones down then as well - assuming that your headphone base unit is connected to the headphone socket of your device.
ALPUG
If this will help, please give this answer some ratings!
Feb 24, 2011 | Sony MDR-RF970RK Headphones
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
The picture is fine but the sound is not working. I push the volume and you can see where the volume level is going up. Have tried turning it off and unplugging it to try to reset it but nothing has...
Hello
Picture being Ok, and no sound output, means there is some problem inside the sound output circuit of your TV. It may be due to a speaker fault or an IC fault. You have to find out which of these has fault.
You just place your ear very close to the speaker side, and switch on your TV with its AC mains On-Off switch, not by remote control handset. Listen carefully, whether there is any sound output of any form comes out of it or not. If there is no sound at all you can determine that the speaker may be out, not in all cases. If you have the habit of listening your TVs audio by using a headphone, continious in-out action could damage your TVs headphone socket. If the headphone sockets' contact got damaged, no sound output will come from it to the speakers. Suppose you can hear the sound through your headphones but not throuhg speaker, means that its change over contact has some trouble. You just do this first. Insert a headphone pin into your TVs headphone socket, if provided, al listen to it for sound. If there is no sound from headphone also, Sound output Ic iside your TV has damaged, or not getting proper voltage to it. If there is sound through the headphone, and not from TVs speaker, trouble is related either speaker or the above said socket.
If all the above has no effect, that is no sound either from headphone, of from the speaker, you should go into the circuit board of your tv to get the fault.
Open your TVs back cover, and trace for the sound output section. There will be an Ic used as sound output. Check whether it getting heated some time after switch on the TV. If it overheats without any sound output, it is damaged Desolder it out from the circuit board, go for a same type and number, replacing it will solve the problem. If it doesn't overheat, or no heat at all, check its input voltage. In some cases, loose soldering points on the legs of Ic may also the cause. Check it too. Ok.
If you need any more clarification, ask me through Fixya. Give
a brief explanation about what you have done so far also.
Nov 04, 2010 | Symphonic ST419E TV
Symphonic volume on my tv stopped working i have
Hi
can sound be heard from headphone socket when a headphone plug is inserted if so headphone socket is faulty or the lound speaker,
Mar 14, 2010 | Symphonic ST419E TV
thank you
May 24, 2009 | Logitech ClearChat Pro USB Headset
No sound through the headphones
Jan 10, 2009 | Dynex DX-LCD37 TV
Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Dec 26, 2008 | Hitachi 26HDL52 26 in. LCD Television
Using headphones with Logitech X-230 speakers
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Dec 25, 2007 | Logitech X-230 Computer Speakers
Sound Problem
Sep 14, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Luxor Televison & Video Experts
sureshd2008
gbob59
rugby prop
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
