Question about Brother Sewing Machines
Does the brother dreamweaver have a feed dog drop down or raise up switch
  • Brother Master
  • 11,703 Answers
Try page S-39 (instructions for Free Motion Quilting on page 127):
Brother DreamWeaver XE VM6200D Operation Manual Troubleshooting
Posted on May 15, 2017
How do you raise the feed dog when they're too far down?
Did you drop the feed dogs? If so, if you re-activate the switch, they should come back up when you begin to stitch again. However, if the feed dogs stay in the dropped position, you probably need to take the machine for service.
Jan 19, 2018 | Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
Why can't I get the feed dogs to come back up?
the slide switch could be broken, also could be a problem with the feed dogs, machine needs to be checked
Feb 14, 2016 | Brother SE400 Computerized Embroidery and...
The piece that moves the fabric is down ( as nedded for embroidery) it should be up for conventional sewing, please help me.
look in the operation manual for the feed dog lever and push it to the up position so the feed dogs will come up..
Jun 06, 2015 | Sewing Machines
The feeder dose not feed
there is a switch on the back of most machines behind the feed dogs that allow you to drop the feet for embroidery, you have to switch it back to raise the feed dogs back up
Mar 04, 2013 | Brother PC-8500 Pacesetter Embroidery &...
Brother CS6000i feed dogs issue :(.
sounds like something may have broke or come loose,, I'd take the machine to someone else to have it checked to see what the poping sound was
Mar 09, 2012 | Brother CS6000i Computerized Sewing...
My feed dods have droped down how can we ajust them to raise them.
Usually when you slide the knob to drop the feed dogs they drop immediately. But when you switch the knob back to raise the feed dogs, they won't come up until you rotate the handwheel one revolution in the forward direction.
Apr 25, 2011 | Janome Memory Craft 9000 Computerized...
My feed dogs will not come up into position
Some machines have to take a stitch for the mechanism to "pop" back into place, I don't really know if your brother is like that but try to sew with it and see if they click back into place.
Oct 22, 2009 | Brother Sewing Machines
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
Feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
May 07, 2007 | Singer 2662
Sewing Machines Logo
50 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
