I got a yellow triangel and an error that said dva fault. It stayed on for 2 minutes and disappered and has not come back
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: There is a yellow triangel with a circle around
This is an anti-slip regulator control cutting in telling you have wheel slippage, and its in the process of stopping the wheel from spinning.
Keep us updated.
Posted on Nov 29, 2010
I have a ALPINE DVA 9861E .Firstly - 1) Will i be able to connect my bluetooth phone to the car deck and play songs from my phone through the car deck wirelessly ? 2) I just downloaded some mp3s...
2 - You've burned songs in a different format than required by your car player
1 - you'd be able to do it through BT if your car has this feature. Just pair them
Apr 25, 2017 | Alpine DVA-9861 Car DVD Player
I have a Canon Pixma iP4000 with a baffling problem. When I turn it on, the lights flash in this pattern: 4 green, 5 yellow, 1 green, 5 yellow, the yellow light stays on for a moment, then the printer goes...
Follow these steps to reset the printer:
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
4.
Jan 27, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
No printing and "service error 5100" the "triangel
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer
Try this solution
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 12, 2011 | Canon PIXMA MP150 All-In-One InkJet...
There is a yellow triangel with a circle around it... the car wont stay cranked unless you hit the gas
Keep us updated.
Nov 29, 2010 | 2000 Volkswagen Beetle
04 Volvo S60 auto yellow triangle anit skid service required
what does the yellow triangle means for volvo s60?
Jun 27, 2010 | 2004 Volvo S60
Display for s80 volvo car maintence keeps popping up on dial;
1. Turn on the ignition. Make sure you have T1 on trip odometer.
2. Press trip odometer some 3 sec, or until you hear a beep or you see an yellow triangel flashing or the previous trip mileage appears.
3. Release the trip button.
4. Turn off ignition.
The service reminder should be reset. Don't forget to service your car.
Apr 17, 2010 | 2000 Volvo S80
Docucolor 12 system fault turn off and turn on problem
tell about error code which is appear left bootom of screen
Aug 25, 2008 | Xerox DocuColor 12 Printer
Disk not recognized...loads, but doesn't succeed in playing disk, displaying "no disc" and stops disc spinning. What do I need to do to get the Mintek DVA 8700 to recognize discs. I've opened it to see if...
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
Apr 17, 2008 | Televison & Video
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
jasbo
jasbo
