Question about whipper snipper Garden
I have a black and decker whipper snipper and the head won't spin are you able to give me an idea what it could be and if I can fix it please ?
SOURCE: Unable to get head of whipper snipper
After much mucking around I noticed a hole in the top shroud of the shaft. I placed a narrow screw driver through the hole until it made contact with the rotating part of the head and pushed until the head would not turn. I thern applied pressure clockwise until the head became loose. I did the reverse to tighten. The head of the unit will rotate anti clockwise to tighten as the shaft rotates clockwise during operation. I hope this explains the method.
Thank you any way for your interest.
Greg
Posted on Dec 22, 2008
evwood
  • 50 Answers
SOURCE: pretensioning starter cord on ryobi whipper snipper.
This was answered in a previous solution
Posted on Jan 03, 2009
SOURCE: my whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Posted on Mar 01, 2010
farmerbear
  • 490 Answers
SOURCE: i have a petrol black
50:1
Farmerbear
Posted on Sep 11, 2010
Testimonial: "Thanks for the info. I've been trying to get the right mix for ages."
anaheimflash
  • 16 Answers
SOURCE: sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
Also check to make sure the dogs are engaging when the cord is pulled. If not manually move the dogs in and out they might be stuck.
If not look at the pulley surface to see if the teeth are still pronounced
and able to engage if they are rounded off you will need to replace
the gear.
Posted on Nov 21, 2013
Where can I buy replacement line spools for this whipper snipper??
I think that might be a K-Mart line of products
Mar 31, 2015 | Garden
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
Whipper snipper revs but head doesn't turn
Englebert the most common thing would be that the inner shaft has sheared off. Remove the head and see if it spins then.
Dec 29, 2013 | Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
Garden Logo
Top whipper snipper Garden Experts
John Mayer
John Mayer
Level 1 Expert
richie46
ray gallant
Are you a whipper snipper Garden Expert? Answer questions, earn points and help others
