Remote showing 61°F, pls advice me how it's showing °C tempature
Nakamichi tv
My smart tv nakamichi, while swith on only shows android and busy, even remote not functioning. . Pls advice
Sep 14, 2011 | Nakamichi VU50P 50 in. HD-Ready Plasma...
TV powers on screan comes and then powers off after a few seconds
Pls look on your remote control, select the "sleep mode" to off. Sleep mode might be on. Or adjust the time whrere what time you want it off automatically. Just simplt turn ot off the Sleep mode. Check timer of your Tv.
Jan 18, 2011 | RCA HD61W66 61" Projection HDTV
I have a gemmy incredible light show trio, daughter dropped remote in dogs water bowl now it wont work, can i get a replacement remote for it? thanks Mike
you can buy a remote at for 20.00 I just ordered one myself they have 61 left click on the accesories and parts on the left.
Nov 17, 2010 | Vacuums
I have a sharp LC-M3700 monitor I purchased used. It has a Pc code on it and will not let me open the monitor without the code. A yellow icon comes up that looks like a remote control with numbers and...
Page 61 of the manual shows how to bypass the pin if the pin number is forgotten with the remote, however you need the factory remote as a universal won't work. If you knew the pin number a universal remote would work to enter the numbers, but i'm guessing that you don't know the pin number in this case and there is no other way to reset it without having the original remote. These monitors were made for commercial use and have a pin lock to protect the settings in from being tampered with in a commercial installation.
May 04, 2017 | Sharp Aquos LC-M3700 37 in. HDTV-Ready LCD...
I have 99 Taurus using from past 20 months. From past 1 week, I temparature gauge is showing Hot during breaking condition (signal lights), when I remove breaking and put it in Parking gear, it is dropping...
From what your saying it starts to over heat at stops, check your radiator cooling fan, sounds like it's not working, could be a fuse or the fan motor it's self.
Aug 19, 2010 | 1999 Ford Taurus
Sansui old model TV SV2110K get locked 3 channels and original remote lost. Now I want to clear the lock. and some channels are not showing now a days. pls advice....
Use the buttons on your TV and go through the menu and do the same thing as you did when you had your remote. If some of the channels are not showing you will probably need what is called a digital box or receiver that you can buy from your Local WAL-MART
Aug 05, 2010 | Sansui Televison & Video
New codes mar 2010 telewest pls
please help telewest 5A 01
CF 53 0C 33 79 61 71 85
52 5E 8D 45 FC 75 F6 4A
Not Working On My ddigital box since 25th mar 2010 ... any one have new codes .... help please .... thaks in advance.
Mar 05, 2010 | StarView IP SV1100KVMIP...
Good day sir/maam, the swiching off thing can be caused by the setup of the sleep mode. check your remote and set the sleep mode to off.
It could also be a failure of the switching power supply board. This symptom needs to be checked by an authorized service service center, better call or visit your local dealer, for proper advice on your TV. Hope this helps.
Oct 13, 2009 | Samsung 61" Slim-Depth DLP HDTV
Lost remote for jamo dmr 61
i have got the remote and i can supply to you for a small fee.
i have got the DMR 61 REMOTE and the DMR60 ALL BRAND NEW.
email me and make me an offer.
Jan 31, 2009 | Jamo DMR 60 DVD Player/Receiver
NFocus ScreenPlay 61md10 61 does not recognize remote
on the universale remotes it tells you on the back of the package what tvs it will and wont work with.
Oct 20, 2007 | InFocus ScreenPlay 61" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
