Question about Home
Spare parts for toilet fill valve - Home
picatudo
  • 239 Answers
SOURCE: Toilet fills up slowly
buy a universal fill valve and replace it
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: Toilet will not fill up
Some Toto fill valves have a plastic debris screen located at the inlet connection. Turn off the supply valve and remove the supply connection at the bottom of the tank. Use a mirror to inspect the screen for debris.
I agree w/ Smithbrother, the Fluidmaster fill valves are cheap and work well. The only thing they ever need is an occasional seal for $1.50 and 5 minutes to replace.
Posted on Mar 14, 2009
  • 3600 Answers
SOURCE: Toto fill valve continual problem, new toilet
There are cheep fill valves and ther better built fill valves, so make sure you buy aa quality fill valve. Also buy a pressuer gauge at ahard ware store and check water pressure level at a faucet outlet. Screw gauge onto water fauct leave a little room for air to escape when water is drippng out tighten the hose bib on the gage turn on the faucet and read the pressure. If it's more than 50 PSI you need to lower the water pressuer. I need to know if your on a, on site underground well,or are on city water to tell you what you need to do to to fix this problem. If there is one. thanks for using Fix-ya if you want more info post here.
Avid101
Posted on Aug 24, 2009
bearsfan7538
  • 119 Answers
SOURCE: I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
Posted on Nov 15, 2009
  • 15 Answers
SOURCE: toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Posted on Jan 26, 2010
Caroma 1991 need spare parts
All available replacement parts for Caroma Toilets can be purchased from this place. http://www.plumbingmall.com/Caroma-Spare-Parts/
They are a master distributors for Caroma here in the states.
Oct 04, 2014 | Caroma Home
Will not stop filling
press on the flapper and see if the water fills and stops filling. If not replace the fill valve.
replace the flapper if when you force the fill valve closed or shut off the supply water to the toilet and it drains out.
Sep 21, 2013 | Toto Orinigal Replacement Part Thu013p 1...
Have the Toto Ultramax II toilet and it was installed 3 months ago. Have an issue where the GMAX fill valve is not functioning properly. The water keeps running because it always go over the fill line....
An installation guide for your toilet can be found here:
http://admin.totousa.com/Product%20Downloads/0GU013Z,%20ONE%20PIECE%20TOILETS,%20V.08.pdf
See the top of page 5 for guidance on setting the water level. Make sure you are turning the screw the correct direction (clock-wise) to reduce the fill level.
Is the refill tube properly connected? Should be connected to fill valve nipple and the other end clipped to direct flow to the inside of the overflow pipe.
Is water flow only through the overflow tube or is there leakage from the flush valve? Being only 3-months old you should not be having problems due to breakdown of rubber seals; however, check to make sure the toilet flapper is properly sealing against the flush valve.
If none of this helps with your problem you made need to replace the fill valve. On page 10 of your guide is a parts list; you can identify your part numbers and shop on-line for an idea of replacement costs:
https://www.totostore.us.com/e2wShoppingCatalog.aspx?parentId=3100066448&parentLink=2100000107:3100066448
Jan 19, 2011 | Toto MS853113S#11 UltraMax Round Toilet,...
The toilet takes a long time to refill after a flush would there be a certain part that is plugged or wore out ?
Is the flapper valve slow to return to the closed postion allowing water to flow through the flush valve? Make sure the toilet flapper is moving freely and is sealing properly against the flush valve. If there is no lengthy or continual water flow in to the toilet bowl then this is not the problem.
Is the water valve on the water fill line to the toilet tank fully open? This may seem silly but it could be this simple.
Check to make sure your fill valve is opening fully. If you have an older toilet there may be some deposits that need to be cleaned way to allow free movement.
If toilet does eventually fill to the desired level, there is no leakage, water valve on fill line is fully open and fill valve is opening fully then recommend you shut off water supply, drain toilet and disconnect water fill line from the water valuve and toilet tanke to make sure there is not a blockage. If the water line and connections are clear you may need to remove the fill pipe in the tank and check for blockage. If this is very old, conisdering the cost and effort, it may be simpler to replace at this time rather than trying to extend the life.
Jan 15, 2011 | American Standard Home
Toilet keeps running water in back tank keeps running over top of drain hole
You don't have to replace, You just need to adjust the fill valve. If you have the ball **** type just tight the top phillips screw. If you have the newer type, close the water valve under the tank and Push down a plastic ring at the bottom of the filling valve, Push down the top of the valve, lift the plastic ring to it's place and open the water valve.
Aug 01, 2010 | Toto Home
TOTO toilet Gmax fill valve
You need Korky Part # R528 available at Home Depot. Instructions are on the package and it takes just a few minutes to change it.
Dec 31, 2009 | Toto Toilets ST784S 12 Sedona Beige...
Tank fill valve sticks
Defective fill valve contact Toto for a free replacement part
Dec 07, 2009 | Toto Drake ADA Compliant Toilet with...
Oct 26, 2009 | Kohler K-3466-95 San Raphael one-piece...
Can't find replacement wter fill valve for Pegasus Cottage toilet
If you replace fill valve with a fluidmaster fill valve that should fix it right up.
Aug 23, 2009 | Home
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
