Question about Kitchen Appliances - Others
Descaling a kettle. How do I descale with a Karcher stick.
  • 2039 Answers
SOURCE: how do you descale the keurig B40
use descaling product not vinegar ,vinegar remove calcium in little piece descaler melt calcium 1 part descaler 1 part water fill water container start machine for a few second turn off let it seat for 15 minute repeat untill empty to reset the lightnormally its maneer of pressing the on button
i get back to you on that one pierre
Posted on Feb 24, 2008
  • 74 Answers
SOURCE: Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
Posted on Jul 14, 2008
SOURCE: How to descale Philips HD 4651/C Electric Water Kettle
Not having received any solution message from FIXYA contributors, I consulted with a family member
and also my long held Time-Life Books, Fix It Yourself Library, Volume: Cleaning & Stain Removal,
ISBN: 0-8094-7400-X, Copyright 1990. My issue was resolved by using white vinegar and soaking the internal problem area for 30 minutes. The appliance has cleaned up like new and works fantastic. I apologize for bothering you.
Posted on Nov 28, 2008
SOURCE: After performing a descaling cycle, the descaling light still flashes, what is wrong?
The manual states that after you descale, you have to hold down the hot water button for 6 seconds, that will turn it off and "reset the timer" till the next time it needs to descale.
Posted on Feb 02, 2009
espressonist
  • 1711 Answers
SOURCE: how to descale
Here are intructions on the link below
http://www.fixya.com/support/r5544114-keurig_home_brewer_instructions_de
Posted on Aug 17, 2010
Does anyone of a company that can repair my Bugatti vera kettle. It powers up but won't boil
When did you last descale it? Chances are that if you haven't descaled it at least once a month, the limescale has caused it to malfunction. You can try descaling it now, but there's no guarantee that this will fix the problem.
May 04, 2014 | Kitchen Appliances - Others
Leaking jug
A common cause is the calcium, or some other minerals in the water eventually ate through the bottom of the tank. You will need a new tank, or better... A new kettle.
Jerry G.
May 07, 2012 | Russell Hobbs RHOK3123 Cordless Electric...
Hi, i have a Bosch TDS2551GB steam generator iron. It needs descaling but I don't know how and there does not appear to be a descaling button. How do I proceed ?
Hi, Descaling is simply a process where the limestone that is deposited in any water cooking device is removed.
Have a look inside your electric kettle to see how much of a problem ypou have in your area.
If you have a serious problem & your kettle element is totally covered up with a whitish coating, I suggest you buy a can of commercial descaling agent.
If not, or iof you prefer home remedies, get a bottle of white vinegar.
Empty your kettle & pour a bit of vinegar onto the limestone. If it boils & foams, it is being dissolved. Replace the vinegar everytime it stops or slows down. Look at the results. You can speed it up by heating the kettle. Do not boil the kettle with vinegar. (Weak acid) Rather dilute it 50-50 I then boil. Or, just boi;l some water & throw it out. Then put the acid on. once you figuted out what process is suitable for getting rid of your areas's limestne, then applie your knowledge to your Bosh.
Just let the acid stand inside it overnight, or get more drastic if neccessary.
Sep 04, 2011 | Bosch Irons
Kettle is noisy. How do I descale?
There are some descaler solutions available that can be bought at supermarkets. After you use any of them please make sure that you fully fill up to the maximum level allowed with water, boil it, drain it (dont use it) twice before it can be used for usual consumption.
You can have a look here http://www.videojug.com/film/how-to-descale-a-kettle
Jun 29, 2011 | Russell Hobbs Microwave Ovens
Can I use vinegar to descale my Breville single cup coffeemaker?
White wine vinegar is a great descaler as it can dissolve the white deposits. For kettles, fill them up and leave them overnight. Don't boil it, though - the vinegar will froth up and go everywhere. Afterwards, rinse the kettle thoroughly, fill with water and boil before using it again. Malt vineger can also be used as the malt only adds flavor
May 05, 2011 | Breville BKC600XL Coffee Maker
What is a cheap descaling substance for my incanto delux
If you are really strapped for cash then vinegar or citric acid will work but be sure to mix with water. Download sunbeam em6910user manual and read descale section for vinegar mixing ratio. I personally would look for a cheap sachet of kettle descaler powder and follow directions ( just as good as expensive name brand pre-mixes like saeco and delonghi and much much cheaper). Most descaling substances are based around citric acid.
Dec 09, 2010 | Saeco INCANTO DELUXE Espresso Machine
Nov 27, 2008 | Philips HD4651 Electric Kettle
Tefal quick cup - descaling problem
Push red and black for 5 seconds to lunch descale then unit resets light at end oy cycle
Hampshireman
Feb 25, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
