My ssagyong kyron start and goes off after washing how can I fix it
How to check automatic transmission fluid in kyron 2008 ?
there may not be a way . but a call to a dealer should confirm how it's done
Mar 19, 2015 | SsangYong Kyron Cars & Trucks
Hard Starting Ssang Yong Kyron M2.0XDI
Yes you will need to bleed the air from the system, otherwise it's not going to run correctly nor will it start properly.. Has the fuel filter been replaced? Has the pump been pressure tested?
May 09, 2014 | Vehicle Parts & Accessories
Ssangyong whistling noise in turbo
sounds to me the blow off valve is working for the turbo mabye deffective .
May 04, 2014 | 2010 SsangYong Kyron 200Xdi
Car will not start when warm
does it happen cause of the weather or after you drive it and the motor warms up? I had the same problem on my old truck after I drove it and the motor warmed up it wouldn't start back up till it cooled down and I replaced the starter and that's fixed it.
Apr 29, 2014 | 2010 SsangYong Kyron 200Xdi
Ssangyong Kyron 2007 shuts down when driving
run fault codes and look for a problem with the TCM ( possible reading and engine over speed which shuts the engine down)and it should re-engage gears immediately upon reselection
Feb 09, 2014 | 2007 SsangYong Kyron 2.0D
Engine wont start after washing engines
stay out of trouble never wash engine.
Feb 23, 2013 | 2007 SsangYong Kyron 2.0D
Ssangyong kyron fan belt
Sent me your e-mail address to polmot@telkomsa.net and I will mail you the correct diagram .
Nov 23, 2012 | Cars & Trucks
Ssangyong kyron wont start when cold
I had a similar problem with my Ssangyong Rexton. Unfortunately, it is the injector pump, the filter gets clogged with micro-particles of crud. Take it to a diesel pump specialist (as a Ssangyong dealer won't know what to do in my experience and they will charge $000's to fix) and get them to remove and clean the injector pump.
Oct 14, 2012 | 2007 SsangYong Kyron 2.0D
Washing Machines Logo
Top Washing Machines Experts
