Question about Sewing Machines
My stitch wont stay in the fabric what am i doin wrong
  • Sewing Machines Master
  • 12,062 Answers
Install a brand new needle--a damaged/bent needle frequently will not pick up the bobbin thread. When the needle thread connects with the bobbin thread, the two threads will be twisted around each other to form a loop.
If the threads are looped around each other but are very loose so one thread can simply be pulled out, then it is a tension problem. The tension is correct when the top and bobbin threads meet in the "middle" of the fabric.
Understanding Thread Tension Threads
If the top thread still does not catch the bobbin thread, most likely the machine is out of time. Search for sewing machine timing or take it for service.
Posted on May 15, 2017
    Top Expert:
  • 50,084 Answers
Needle thread tension worng
no thread in the bobbin
neeld /hook timing is wrong
Posted on May 14, 2017
How do i sew a hem with a twin needle?
Sewing a hem with a twin needle is done differently than with a single needle. Normally you stitch on the wrong side of the fabric but in twin needle seeing you stitch on the right side of the fabric. Using fusable stay tape to keep the hem in place to sew the hem works well.
This video should be helpful. Watch it in it's entirety and remember some things on your machine may be different.
Sewing the hem will be the same.
https://youtu.be/t5eEPCj-LGE Sewing with Double or Twin Needle
Jul 21, 2017 | Sewing Machines
How to sew a hem with a twin needle please?
How to do blindstitch hem with a pfaff 1035. I have the blind stitch foot
You need to also have a blindstitch stitch on your machine. It looks something like this:
-------V--------V--------V-------
The straight stitch segment is stitched on the hem fabric, but the V portion zags over and catches a couple threads in the fold on the wrong side of the garment fabric.
Blind Hem Stitch with sewing machine Make It and Love It
Feb 22, 2017 | PfaFF Sewing Machines
My Memorycraft 6600 zig-zag stitch is not working. The fabric would not advance and the needle comes down ******* the metal if I try to shorten the width of the stitch.
suggestions
if the zig zag stitch is not working could be something wrong with the cam
try taking the bobbin out & use a different bobbin
try a new needle, make sure the needle is correct for the fabric being sewed
could also be a problem with the feeddogs
Feb 07, 2016 | Sewing Machines
My runaway stitches on wrong side of fabric
Rule of thumb:
1.Too much thread on bottom then tighten top (tension).
2. Too much thread on top then loosen top (tension).
Just remember this works very well only if your bobbin is set properly.
Apr 05, 2015 | Brother Sewing Machines
I have a designer SE it wont stitch tee/shirt material it misses stitches
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Feb 01, 2013 | Sewing Machines
The lower stitching on my machine is not consistant, why?
Wrong size needle or wrong type of thread for the weight or type of fabric. For instance, you should use smaller needle size for light weight fabrics.
Jan 15, 2013 | Sewing Machines
I am sewing a knit fabric on my Lily 540 and it is skipping stitches like crazy. I have tried adjusting the tension and the stitch length with no success. seem to always have a hard time with getting even...
It sounds like you may be using the wrong needle. For knit fabric you need a ball point needle in order for it to sew correctly. A regular sharp type needle can cause the stitches to skip. Also make sure you have the right size for the type of fabric. Lighter weight fabric needs smaller size needle and thicker types need bigger sized needles.
Also make sure you have the right presser foot and the right pressure on the presser foot to get nice even stitches. A roller foot helps when sewing knit fabrics.
May 18, 2011 | Husqvarna Lily 540 and 550
What settings for doing zig zag for satin stitch around applique. I have used 3.5 width and 0.2 length but the fabric has a tendancy to pucker and the stitches sometimes bunch
It depends on a couple of things. Depending on the fabric you're using you might want to use a stabilizer like an iron on tear away. If the stitches are bunching the stitch length might be to tight. Try going to 0.3. if the stabilizer doesn't work. With the stabilizer on, it will keep the fabric firmer so it won't pucker. Make sure you have the decorative stitching foot on the machine with the little indentation for the satin stitch to ride in. If you have the wrong foot on, this will cause bunching too. Let me know if this helps.
Aug 22, 2010 | Janome Memory Craft 4900QC Mechanical...
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
