Question about Cub Cadet Garden
Our cub cadet riding mower parking brake sticking
5 Suggested Answers
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
SOURCE: cub cadet z force mower dies after releasing park
According to the wiring diagram in my ?07 Z-Force manual, a malfunctioning safety switch under the seat is the only device which could cause this problem. Try flipping the seat upside down and locate the seat safety switch. Pry the locking tab out and remove the connector from the switch. Make sure the PTO is off and the brake is set and try starting the engine again. Release the brake again. If the engine doesn?t die this time, the seat safety switch is either defective or not being activated when the seat is occupied. The switch should be closed when unoccupied and should open when the seat is occupied. I wouldn?t recommend normal operation of the mower with safety switches defeated or disconnected.
Posted on Oct 07, 2009
alicantecoli
  • 22095 Answers
SOURCE: I have a cub cadet 2146 riding mower. I've changed the battery and replaced the fuses, still no power. What else could the problem be?
check the battery connections and also the earth cable if no luck their then check the fuses with a test light or similar and look for a feed to the fuses as the connections at the back of the fuses could be corroded
Posted on Nov 23, 2011
  • 6468 Answers
SOURCE: cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
Posted on Jun 04, 2012
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Why does my mower die when you release the park brake ?
Sounds like seat safety switch.To check switch use a piece of wire unplug seat switch under seat. stick wire in both sides of plug to complete circuit and try to use mower. If works replace switch.
Jun 14, 2014 | Mtd Cub Cadet 48 In 22 HP Kawasaki Engine...
Trying to jump (with my car, I know it's not good) my cub cadet LTX 1046. Worked a few times. Now the parking brake light comes on when I try to turn it over and the motor won't even try to start. Nothing....
Find the switch attached to the parking brake mechanism. It's probably stuck. Jumping with a car will not hurt it if it uses a 12 volt battery. The car is not "too much power" for it. The mower will only take what it needs.
Nov 03, 2013 | Cub Cadet Garden
Seem like brake is locking up
do not use parking brake when moving only when stationary
Apr 07, 2013 | Cub Cadet I1050 50" 25HP Zero Turn Tractor...
Cub cadet riding mower wont start... parking brake feels loose wont turn over
Jun 03, 2012 | Cub Cadet 42 And 54 Inch Blade Operator's...
I have a cub cadet model 3184 i want to be able to mower in reverse it used to all of a sudden it started disengaging the mower when i push reverse pedal.
There are 3 switches to check. The Brake switch, the parking brake switch and the reverse switch. Any one not funtioning properly will cause this symptom.
See this manual page 82 for the Brake and Reversing switch locations:
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-02100.pdf
The parking brake switch is under the parking brake handle. It is not shown in the manual.
These are all make or break switches. Check resistance across the terminals in both actuated and extended positions. I think there may be a problem with either the pedal / brake switch or the reversing switch.
Wiring can also cause this same problem.
Thanks for choosing FixYa, Kelly
Aug 01, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Apr 18, 2009 | Briggs & Stratton Garden
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
