Question about Kenmore Dishwashers
KENMORE UNDERCOUNTER DISHWASHER HOOKING UP TO water heater ,
3 Suggested Answers
SOURCE: Kenmore Elite Dishwasher Problem
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Posted on Nov 10, 2008
  • 93 Answers
SOURCE: Convert a whirlpool portable dishwasher to undercounter
I would simply slide the unit under the counter and connect the inlet and drian hose permenantly.If the unit is not tall enough and sits too low then build a shelf or false floor in the cupboard for it to stand on.
Posted on Dec 30, 2009
Water continues coming
Hobart ' Undercounter Dishwashers, Commercial ...
www.hobartcorp.com/.../commercial.../undercounters...
Hobart CorporationGlasswasher ... The LXe undercounter is ENERGY STAR® qualified, uses only .74 gallons of water per cycle and features new Smart Display technology to eliminate error codes. Loading... Highlights: Hobart undercounter dish machines are the most popular in the industry, keeping reputations spotless all over the world.
Advansys LXe Undercounter ' Hobart
Hobart CorporationGlasswasher ... The Hobart LXe Undercounter Dishwasher is designed to pack best-in-class cleaning power into a compact space, ... The Advansys LXe low-temp model features PuriRinse, a cold-water rinse that removes chemical residue, ...
[PDF]AM15 Technical Manual - Hobart
https://my.hobartcorp.com/kroger/.../AM15%20Technical%20Manual.pd...
Steam Booster, if used based on 20 PSI steam - 20 PSI water flowing. 130°F entering.... DRAIN AND OVERFLOW: Large bell type automatic overflow and drain ...
[PDF]Glass- and dishwashers - Hobart
Dec 08, 2015 | Hobart Undercounter Glasswasher w/Chemical...
Tip
How to make your undercounter dishwasher clean better.
Run the water at your sink until it is as hot as it will get and use liquid detergent. Many be you have your water heaters set at 120 degrees for saftey but that is to low for powered detergents.
on Sep 16, 2010 | Dishwashers
How do I mount Kenmore dishwasher model 65515779 to granite counter top?
Joanne,
You need a granite/stone counter-top mounting kit. It will be a metal strip that you can attach to your cabinets and allow you to screw some short screws up into that metal strip. I would think that most major home repair dealers would have something like that. Dishwasher Undercounter Mounting Kit W10426979 The Home Depot
May 13, 2015 | Kenmore Dishwashers
How does the heater work
If you looking for the heating element details on this dishwasher then refer to page 43 and 44 on this manual
http://www.webstaurantstore.com/documents/pdf/wareforceundercounter.pdf
it is a typical coil heater working on 400V for rinse water. I thing wash water heating unit is an additional option.
Apr 23, 2014 | Wareforce UH30 Undercounter Dishwasher -...
Dishwasher keeps running to long
Most likely the hot water temperature is the problem. If you have a separate hot water inlet check that the water temperature is ok. But if you only have a single cold water inlet then the heater inside dishwasher may be faulty. Check if the dishwasher is still cold when you terminate the cycle.
Heater is part 13 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66515752000/0582/0130000/P0101063/00003?blt=06&prst=&shdMod=
Apr 04, 2014 | Kenmore 665
The clean light in my Kenmore dishwasher keeps
It has to do with the water temperture, either the water entering the dishwasher is too cold and the heater can't get it up to temp, or the heater unit has problems... Push the Air dry ,then the sani wash buttons a few times and all the lights will light, it resets the computer .
Nov 02, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Need to hook up the small pipes for sanitazing agent
The other pipe is for detergent.Any other questions let me know i'm a hobart tech.
Apr 12, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Apr 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Model 665/157874000/Undercounter Dishwasher
Hi First I would check to see if the water may have been turned almost off under the sink, it will be the Hot water side. if that don't help then check for something plugging the line. let me know what you find, or we can go deeper krazytech
Aug 30, 2007 | Kenmore 24 in. 15874 Built-in Dishwasher
Dishwashers Logo
35 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
