Question about Retail Supplies
XE A207W cash register unresponsive Attempted to master reset = unplugged machine. Removed batteries and left for a few minutes. Turned back on (without batteries) and no response from key pad?
flexion1
  • 737 Answers
SOURCE: how do you reset sharp xe-a302 cash register to factory defaults
Hi.
I would not recommend doing this unless you are certain that it is the cause. I have never had memory corruption in this series before, so I would strongly suggest it is being caused by another factor such as spillage in the keyboard.
Can you tell me exactly which buttons are showing the problem and what happens when you press them. Can you still make sales with the product buttons?
Mark
Posted on Nov 29, 2008
ThePhantom
  • 6 Answers
SOURCE: Sharp electronic cash register XE-A203 - keeps printing receipt
I don't have this particular cash register, But I took a look at the manual and I recommend the following:
A. Turn the cash register off.
B. Unplug it.
C. Remove the batteries.
D. Wait at least five minutes.
E. Initialize the cash register. This procedure was copied from thwe manual:
In order to operate the cash register properly, you must initialize it before operating for the first time. Follow this
procedure.
1. Insert the manager (MA) key into the mode switch and turn it to the REG position.
2. Insert the plug of the AC power cord into the AC outlet. The buzzer will sound
three times.
IMPORTANT: This operation must be performed without batteries installed.
3.
The cash register has now been initialized. The register display will show
"0.00" and then “NO BATTERY”.
If the buzzer does not sound when the plug is inserted, the initialization has not been done
successfully. (This will occur when the voltage is high because you operated the cash register
before starting initialization.) Wait at least one minute after pulling out the plug and insert the plug
again.
F. Download trhe manual from here:
http://www.ormsson.is/skjol//skrifstofutaeki/xe-a203,213,303_manual.pdf
And proceed to program your sales tax (or VAT), departments, clerks, etc.
Posted on Jan 26, 2009
SOURCE: ipl for sharp cash register XE-A203 / XE-A213
MY NEW ELECTRONIC CASH REGISTER SHARP XE-A203 DSPLAYED IPL ON IT . WHAT DO I DO??
Posted on Jul 05, 2010
SOURCE: How do I reset the grand totals to zero on my
Go to PGR, hit tm/sbtl, then hit 64 (black keys) @10 (black keys again), tm/sbtl. Then go to x1/z1 and hit decimal point and then ca/at/ns. Do the same with x2/z2.
Posted on Oct 06, 2011
Electroboy
  • 1750 Answers
SOURCE: E 32 CODE ON A XE-A206 CASH REGISTER
E32 means no one has signed on to use the machine.Try 1 then CLK# button.
If anyone needs a manual, C-tech have the Sharp XE-A206 user and programming manual here:http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A206_operation_manual.html
Posted on Nov 03, 2011
My XE-A201 reset itself overnight. I did reprogram, but next morning was reset again.
Yes, the cash register uses batteries.
Without the batteries in each time you turn the cash register off you are, in effect, performing a master reset.
See page 7 of the Sharp manual here: http://www.sharp-cash-registers.co.uk/acatalog/Cash_registers_xea201_manual.pdf
Thanks,
Ben
Sep 12, 2016 | Retail Supplies
Return Sharp XE-A102 cash register to factory settings
MASTER RESET
Master reset: Clears all the memory and initializes each preset parameter. The master reset should be performed by using the following procedure.
1. Turn off the power (Power OFF). (See Note 1.)
2. Remove the memory back up battery from ECR.
3. Turn the mode switch to any position other than Power OFF.
4. Turn on the power (Power ON). (See Note 2.) When the master rest is completed, the buzzer sounds three times.
5. Install the memory back up batteries back into the ECR. The master reset can also be accomplished in the following case. (See Note 3.)
Note 1) Power OFF: Means disconnecting the AC power supply to the machine. (Specifically, unplugging the machine.)
Note 2) Power ON: Means connecting the AC power to the machine. (Specifically, plugging in the machine.)
Note 3) In case a power failure occurs when the machine has no battery installed, the master reset operation is automatically performed after the power has been restored.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 05, 2016 | Sharp XE-A102 Cash Register
How do I reset memory on a XE-A404 cash register?
remove the three aa batteries from under where the paper sits . unplug the register for thirty seconds . then plug it back in and replace the batteries. Cash register will be restored to out of the box settings
Oct 14, 2014 | Retail Supplies
Reset the xe-a-23s to factory
Just remove the batteries and take it off the mains for about 2 minutes and then plug it on again
Mar 08, 2014 | Sharp XE-A23S Cash Register
Have the sharp xe-a404 cash register and cant get last year totals off
If you still have book it explains how to do master reset 'if not un plug from a/c and remove back up batt which should be under paper roll wait 5min before replcing batterys if over 2years old replace before they start leaking
Jan 07, 2011 | Sharp XE-A402 Electronic Cash Register
Hello i have a sharp xe-a1010 cash registar and it froze. ive tried unplugging and reseting it but no luck. ive also tried the clear-escX2-subt# and nothing works.. help please thanks
I think you mean an XE-A101. Try turning the key to REG mode, take one battery out, turn off at wall for 10 minutes, turn on at wall. Put battery back in. NOTE you will lose any sales in the machine. If this doesn't work, then it is usually a keyboard or printer problem.
If anyone needs a manual for a Sharp XE-A101 cash register, c-tech has it here: http://the-checkout-tech.com/manuals/TOC/cashregisters/Sharp/XE-A101%20operating%20programming.TOC.pdf
Nov 26, 2010 | Casio Parts Cash Register PC Desktop
Sharp xe-a102 is stuck in program mode
Unplug the machine and remove the batteries, Leave it for around 5 mins. This will reset the machine to when it was first taken out of the box. Please be aware all data in the till will also be lost.
www.shopstuff.co.uk
Oct 09, 2010 | Sharp XE-A402 Electronic Cash Register
B. Unplug it.
procedure.
three times.
3.
again.
Jan 25, 2009 | Office Equipment & Supplies
Retail Supplies Logo
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
