Question about Ice Cream Makers
I need the plastic nut that locks the paddle and ice cream bowl in place for my gaggia gelatiera can you help?
    New Friend:
  • 124 Answers
Gaggia ice cream machine
Ice cream won't churn but the freezer it's on
Nov 24, 2013 | Gaggia Ri9101/08 Gelatiera Ice Cream Maker
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions '
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    I need a metal bowl for a Gaggia Gelatiera. Where
    julie, I purchased two additional metal bowls from AA Food Products. It is located in NJ. The phone number is 201-935-4500. I purchased them several years ago. Hopefully, they are still in business. Jeanie
    Dec 29, 2009 | Ice Cream Makers
    Lumina (Aldi) ice cream maker instructions
    Before using the first time:
    1. Remove all of the packaging.
    2. Wash the parts. (the paddle & the bowl only)
    3. Eight hours in advance, place the inner bowl into a freezer.
    4. Prepare the ice cream or sorbet mix (see recipe ideas)
    Allow the mix to cool in the refrigerator.
    FYI, I freeze the inner bowl overnight instead of the eight hours as stated in the manual.
    Sterling ice cream maker-whole container turns, instead of just paddle.
    You need to be sure that the bowl is locked in the ccling well, usually a lever in the front of the larger machienes does this. hope this helps
    Jul 05, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
    Ice cream maker instructions
    I have the booklet for this machine.
    1) you can use any IC recipe as long as it does not exceed 1 quart. This is for vanilla:
    1/2 c sugar
    1 1/4 c half&half
    1 1/2 c heavy whipping cream
    2 eggs 2 tsp vanilla
    with mixer beat eggs and sugar until thincl and cream colored. Addthe cream and vanilla mix well.
    the machine:
    you want to put the freezer cylinder in a plastic bag (to prevent freezer burn) and then put it in the back of your freezer until completely frozen 6 to 22 hours. You should not be able to hear liquid slosh when you shake it. For making stuff quick they recommend keeping it in the freezer in the bag.
    step one: Put maker on flat surface.
    two: Put the mixer bowl on the base.
    three: Place frozen cylinder into to the mixer bowl (the big one) do this when you are ready to start the IC because the cylinder begins defrosting right away.
    four: set the paddle on top of the cylinder, placing the peg on the freezer cylinder inside the peg hole on the paddle
    five: Place the cover over the mixer bowl, locking the grooves on the motor base. Plug in, turn on, the bowl and cylinder will begin to turn.
    six: Pour the recipe into the feeder hole of the cover then put the lid on.
    You will need 20 to 40 minutes or until mixture is frozen. Don't stop the machine until done. If you want hard ice cream spoon the soft serve into an airtight bowl and put it in the freezer till it is like you want it.
    Hope this helps, Elizabeth
    May 17, 2009 | Ultrex Double Canister 2 Quart Ice Cream...
    Mixing arm/bowl will not turn once machine is turned on
    The only thing I can really suggest is to make sure the easy-lock button is fitted into the right place on the lid, and to make sure that the ice cream mixture is not too thick. But, if the turning paddle is locked into place properly, and the mixture is still in liquid form, then there is a problem with one of several parts - could be the metal sliding switch or even a motorized part. These parts cannot be replaced. It is worth a shot to replace the mixing paddle - the unit has a 3-year warranty, so I would Call Cuisinart to get the part instead of ordering it online - they may or may not give it to you for free. If the new mixing paddle still won't spin, get the unit replaced either thorugh the store (depending on the store -each has a different policy) or get it replaced directly through Cuisinart. This model is actually pretty solid, so a second one shouldn't give you any problems.
    -Tha Mp3 Doctor
    Mar 05, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
    Replacement paddle for my cook's essential ice cream maker
    try contacting the manufacturer they may be able to help.
    Nov 11, 2017 | Cook's Essentials Ice Cream Makers
    Deni Ice Cream Maker Manual
    I don't have a flatbed scanner to scan it, but here are the operating instructions (at least for the 5201).
    1. Place canister in freezer for 8 hours (must be frozen solid-so that you can't hear liquid in canister sloshing around)
    2. Prepare your ingredients ahead, and chill them for best results.
    3. Take canister out of freezer and place on motor base. Use canister immediately after removing from freezer, as it will begin to thaw once placed at room temp.
    4. Place the paddle inside container. Be sure the tould side of the paddle faces up.
    5. Lock the lid (the clear plastic piece that fits over the container)onto motor base. The tabs on the bottom of the lid should line up with the indentations in the motor base. This ensures that the lid is locked in place. When fitting the lid onto the base, the stir paddle should "fit" into the lid.
    7. Slowly pour the mixture in the top opening of the lid. It is at this time that you place the top on the clear-vue lid and leave the machine on for about 5-30 minutes (time varies, depending on the coldness of ingredients and canister, and desired consitency) If making ice cream, your result should be a soft, custard-like ice cream
    8. When the frozen dessert is ready, make sure the unit is off. Remove the lid and the mixture from the bowl with a plastic spoon or scoop. NEVER USE METAL INSTRUMENTS IN THE CANISTER.
    9. Ice cream will be custard-like. If you prefer hard ice cream, place in freezer in air tight container and allow to set until it reaches your desired hardness. Don't put the ice cream in the canister in your freezer for more than 30 minutes, as the ice cream will freeze solid to the container and possibly damage it.
    Hope this helps... If you need something else, let me know. I will try to check back soon.
    Apr 14, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
    No power to the unit
    Make sure the bowl and mixing paddle are in correct place, and that lid is locked into place. Turn dial to on and try again. If this fails to resolve, replace it -has a 3 year warranty.
    Oct 28, 2007 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
    Ice Cream Makers Logo
    61 people viewed this question
    Top Ice Cream Makers Experts
    Andrew Taylor
    Andrew Taylor
    Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
