Question about Imperial Office Equipment & Supplies
Convert 1 pound imperial to metric - Imperial Office Equipment & Supplies
    Top Expert:
  • Imperial Master
  • 48,204 Answers
1 lb = .373 kg ( troy)
Posted on May 14, 2017
Please convert 5'8 into CM and 160 pounds into KG
5'8" = 68"; 68" = 172.72 cm
160lb. = 72.5748kg.
Oct 31, 2017 | Office Equipment & Supplies
If it says 1 teaspoon of wormer =5ml then how many cc per pound
what you are really asking crosses over from measurement of volume to dosage per weight and there is no method to do that
the direction for dosing will say how many ml to use per pound of animal
so if it is 5ml per pound of animal , weigh the animal and multiply that by the 5ml and you will get your answer
Aug 16, 2017 | Office Equipment & Supplies
How to find diffrent unit standerds relating to boilermaking
The basic principle is that it would use the customary or legal standard units for the particular country.
For instance in the US, although the metric system is legal, the American imperial (modified British) system is still used. Hence boilermaking specs and drawings would usually be in inches, feet, US ounces and pounds etc.
In Australia it has all gone metric long since, and units are in metres, mm, grams and kilograms etc. Boilermaking as a trade is nearly dead, but would be metric.
In the UK all packaging and food sales must be in metric units, but otherwise metrication is self-regulating and more or less voluntary. Because of the vast amount of equipment and tooling which has still imperial units inherent in it, much manufacturing there still uses imperial units. Boilermakers could see either system.
Mar 20, 2017 | Cars & Trucks
How do I change from cm/kg to inches/lbs?
Convert inch pound to kg cm - Conversion of Measurement Units
Quickly convert inch pounds into kg cm (inch pound to kg cm) using the online calculator for metric conversions and more.
Jan 21, 2016 | Schiller Cardiovit At 2 Light Ecg Machine
I have staples BD-6350M Metric Conversion caluctor and i am just stuck on how you use it to convert the numbers
Hi lemony fresh Oooo!!
I have a very similar cute little calculator. Don't you think that's nice?
I can't make out the print above each key, so I'm assuming:
1.- The arrow key (under M+) pointing to the right is TO METRIC
2.- The arrow key (under M-) pointing to the left is FROM METRIC
Above all the other keys youll see things like incm, ftm, lbkg and so on.
Now for this example, most people know that 1 inch = 2.54 cm
Just as an exercise, we'll convert 10 inches into ??? cm OK?
You know the answer of course, so you'll know if the key sequence was correct, right?
The key sequence is:
1. Enter the amount. In this case it is 10
2. Now press the TO METRIC key.
3. Now press the key under incm
The answer is displayed immediately! .... 25.4
Now, you get a package that weighs 1 kilo and you need to know its weight in pounds.
(pound = libra .:. lb)
You already know the answer before hand, 2.2, so let's find out if the key sequence is correct.
1. Enter the amount. In this case it is 1 ( 1 kilo )
2. Now press the FROM METRIC key.
3. Now press the key under lbkg
The answer is displayed immediately! .... 2.2045855
For practical purposes, the accepted norm is to say: 1 kilo=2.2 lbs
The little leaflet that comes with the calculator is not very helpful, so I went through the same pains initially.
I trust this has shed some light on the subject.
Jun 30, 2011 | Office Equipment & Supplies
Convert metric weight to pounds
1 Kilogram (Kg) = 2.20462 Pounds (Lbs)
1 Pound = 0.453592 Kilograms
See the following links for Online Conversion Calculators:
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Good luck.
Apr 22, 2011 | Office Equipment & Supplies
I do not have a problem with the machine. I am curious about the plate numbers. On an american sewing machine, the plate the fabric feeds through, normal have 1/4, 5/8, etc. On the Euro Pro Denim Model ...
So an American machine has imperial seam guides on the needle plate.
But the Euro Pro would be European and in metric so it has seam guides in metric widths, i.e. millimetres. 10 will be 10 millimetres, or 1 centimetre, 16 mm, 22mm.
A normal seam in metric is 15mm - in your land 5/8", the two are not quite the same but pretty close. This link gives you a converter between the two systems.
A 1/4" is your standard piecing seam for the quilters and this is why many Australian quilters will buy a 1/4" foot so they can guide the fabric along the foot edge to get nice standard seams.
So you could break out some masking tape and a metric/imperial ruler and measure from the needle to the right and put a strip of tape onto your needle plate to mark your 5/8" dimension you are used to. Or use the 16mm seam marking which is very close anyway.
Hope this helps.
Mar 09, 2011 | Euro-Pro Denim Sewlution 380 Mechanical...
I have a ti-30xa and need to convert metric t standard or other way around
Sorry, the TI-30XA does not offer unit conversion functions other than angle units. The best thing you can do is to get the conversion factor from a table in a book, or look it up in the internet, and store it into one of the three M memory places of the calculator.
Use the memory recall and divide or multiply to convert.
Example: Convert metric tons (Mg) to international avoirdupois pound (lb), and vice versa. Conversion factor is:
1 lb = 453.5937 Mg.
  • Key in 453.5937 [STO] [0] to put the conversion factor in memory 0.
  • To convert 17 Mg to lb, key in: 17 [÷] [RCL] [0] [=].
  • To convert 5 lb to Mg, key in: 5 [×] [RCL] [0] [=].
Jan 16, 2011 | Texas Instruments TI-30XA Calculator
29 people viewed this question
Top Imperial Office Equipment & Supplies Experts
Are you an Imperial Office Equipment and Supply Expert? Answer questions, earn points and help others
