Question about Home
The numbers are out in my atomic clock, what i need to do. thanks
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
SOURCE: Sharp Atomic Clock Daylight Savings
I have misplaced the manual for my sharp Atomic clock, need to reset the time zone and shut off the alarm. How can I obtain a new manual?
Posted on Jul 10, 2008
SOURCE: Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Posted on Apr 30, 2009
SOURCE: Need instruction for setting clock model # 38229-1
Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
Posted on Mar 14, 2010
  • 5 Answers
SOURCE: I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
Posted on Jun 03, 2010
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more :
    Jan 29, 2015 | Audio Players & Recorders
    I have an "SKYSCAN" atomic clock. seven days ago I replaced batteries. Has not reset as of yet.
    Get into this link. You can see the user manual for your Skysacn atomeic clock here. You can adjust your clock according to it manual. OK.
    Nov 11, 2011 | SkyScan 86709 Atomic Wall Clock
    I have an acurite atomic wall / weather clock but the outside temperature is reading blank. I changed the batteries in the transmitter but still no reading. Where can I purchase a new transmitter. The...
    I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
    Dec 03, 2010 | SkyScan 86742 Digital Atomic Wall Clock
    Global atomic radio controlled clock
    It should automatically reset to the correct time. Try taking the model number and Google for an answer. Hope this helps.
    Mar 16, 2010 | Audio Players & Recorders
    AI can't figure out how to set the atomic clock
    This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
    If it does not correct it;s self change walls and location in your house.
    The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
    Hope this tip helps.
    Feb 13, 2010 | SkyScan 86709 Atomic Wall Clock
    I need to change time zone on atomic clock to EST
    I need help setting the time zone on the sharp atomic clock model #spc364.
    Apr 18, 2009 | Bose Wave Radio
    RCA atomic clock radio didn't reset to DST
    Perhaps you've already tried this but on my atomic clock I have to select the DST option and make sure you're in the correct time zone.
    Mar 09, 2009 | RCA RP5430 Clock Radio
    Oct 17, 2007 | La Crosse Radio Controlled Atomic Clock
    Home Logo
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
