Question about Refrigerators
My Frididaire side by side refrigerator Model GLR5267ZCW1 Keeps popping the Pure Source 2 water filter out. I have tried 2 new filters with the same result, after installing the filter per instruction
5 Suggested Answers
  • 5 Answers
SOURCE: Frigidaire Pure Source 2 water filter keeps popping out.
My parents frig had the same problem. The steel tabs that hold the filter in place are very small and frail. Heres what I did to solve the problem, at least temporarily. While firmly holding the filter release button, gently bend the tabs together using an extra long pair of curved needle nose pliers.
Posted on Jul 09, 2009
Testimonial: "Great Advice, and it worked!"
garing
  • 998 Answers
SOURCE: water leaks from the pure source filter
vaseline on filter threads and tighten...thumbs up...
VE6GAR 73 88 99
Posted on Aug 10, 2009
EllaWatson25
  • 725 Answers
SOURCE: water leaks into cabinet fron filter
You need a new filter housing to stop this from happening. You can repair this yourself and save a ton of money!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST with your brand and model number and we will get the correct part out to you asap. We also provide part removal/installation instructions for you when you get your parts through us.
We hope to hear from you soon and we hope you have a terrific New Year! Thanks, Ella
Posted on Jan 08, 2010
s463sergio
  • 3 Answers
SOURCE: Pure Source 2 Filter keeps popping out...Just replaced it. No pressure changes and the old one , still works fine..if I put it back in...but the new one just pops out after about 10 min or 5 or so gl
Is it the square filter that goes in the upper right hand corner inside the refrigerator? If it is, you will need to replace the filter holder.
Posted on Jan 01, 2014
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
Frigidare filter pure source 2 keeps popping out
call frigiadaire about this they have a fix that they pay for the repair because there filter it a little different know.
Aug 31, 2014 | Frigidaire Refrigerators
Where do I find the filter that needs to be changed
Hi
There are two types of water filter fitted to this model they are both located in the top right hand corner of the refrigerator section.
1. The standard water filter looks like an upturned bowl, to change this you need to unplug and switch off the unit, turn off the water supply and unscrew the filter around 1/4 turn anticlockwise.
Replace the filter and tighten the bowl checking that the O rings are in place. You may make a bit of a mess with water dripping out as you remove the filter bowl. These can be quite stubborn if they have not been changed before.
2.Pure source filter is on the face of the unit next to the thermostat, again shut down the unit and turn off the water before removing the filter, there is a small button lower right on the face, when you press this the filter should pop out, again spilling some water.
It is vital that you prime the system properly before using the water or ice this means running at least 2 gallons of water out of the water valve on the front to make sure that all the air is out and that pure water is in the machine.
You manual is available at this link
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241856000en.pdf
Hope this helps
Gordon
Apr 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
Water leaks into cabinet fron filter
Just contact us at:
Jan 08, 2010 | Refrigerators
Replaced leaking filter but still leaking
Where is it leaking?, at the filter?, at the hook-ups on the filter?
Aug 22, 2009 | Frigidaire FRS23R4A Side by Side...
Water leaks from the pure source filter
VE6GAR 73 88 99
Aug 10, 2009 | Frigidaire FRS3R5EMB Side by Side...
Apr 15, 2009 | Refrigerators
Filtered water quit working on my Frididaire side by side
Can you remove a line from the back rear of the unit and see if water flows there? The solenoid valve should make a solid "click" when the water lever is pushed. Any debris in the valve filter screen? See if you can reach up or look inside to see if the water lever is actually pushing the door mounted switch in, may be able to press switch with your finger if you can reach it or with a pencil, etc.
Aug 20, 2006 | Frigidaire StandardDepth Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
