Question about Music
Need schematic for biamp series 24 mixing console. Or pinout info for connector cable from power supply PS-24/28 to console. I have pinout info on power supply side; need console side.
Biamp series 24 mixing console serial number 080368
2 Suggested Answers
chop71014
  • 124 Answers
SOURCE: manual for biamp series 24 mixing console
https://www.manualslib.com/manual/940051/Biamp-24-Series.html
Posted on May 14, 2017
Manual for biamp series 24 mixing console
May 14, 2017 | Music
I need a schematics power supply for MX9000EURODESK
Check out elektrotanya.com you can get 2 circuits per day or pass the electronics test for more. Good Luck!
Oct 01, 2014 | Behringer MX9000 EURODESK 24 Channel In...
How do i biamp these speakers they have a biamp plug in the rear do i need a special cable to do this
The two input jacks are parallel connected, to allow you to chain extra speakers together. There is no facility on this model to bypass the crossover and bi-amplify horn and driver separately. Nor should you need to. Just make sure you use a power amp rated for at least 400 watts per channel at 8 ohms.
Sep 23, 2011 | Peavey PV 115 Speaker PA Passive
I need to replace the transformer. What is the specification and where can I get one? Thanks
The internals run on +/-15 Volts and +5 volts. While schematics show the audio and digital circuits they fail to show the power supply. I suspect the supply uses regulators such as the 7815 family so one would want around 18 to 20 volts DC of each polarity.A transformer would likely be about a 28 to 30 VAC centertapped. HOWEVER transformers rarely fail. There should be fuses to protect the transformer. Some Behringer equipment uses a switching supply. Common failures in those is the switching transistor. When testing these units, it is useful to place a 25 watt incandescent lamp in series with the power cord to save fuses and act as a resetable fuse that will send a limited current into the unit for testing.
Jun 14, 2011 | Behringer Pro Mixer Djx750 Professional 5...
Power surge has blown components at input to the power supply unit SMPSU17. I need schematic to help identify the correct replacement components. John at Topaz Repair Limerick.
Behringer re-uses a lot of design... you might look at page 2 of this download:
http://elektrotanya.com/behringer_pmh100.pdf/download.html
Scroll down to "Get Manual" and click to download. On page 2 is the SPS400 power supply which is one of the smaller switching supplies they use. You may find the schematic is close, possibly they de-populate it as a smaller supply. When repaired, start the supply for testing with a 60 watt light bulb in series with the power input. Use an isolation transformer for troubleshooting for safety.
Apr 27, 2011 | Behringer Active 150Watt PAMonitor Speaker...
My Behringer XENYX 2442FX Mixer does not power up, the only light that comes on is the phantom power light. I opened it up and noticed that the switching power supply has multiple voltage outputs. We...
You should find +/-15 volts and +5 volts as well as the phantom power... but that light can come on at much lower than desired voltage.
Note that the regulators are current limited so a short on the mixer board can kill one of the voltages.... but you are not getting any input from teh switching portion of the regulator so the switching part of the supply is apparently dead. To replace the supply you would have to call Behringer at 1-425-672-0816 to get the part number and an incident number and then call FullCompass which is their part distributor now.
When working on a switching power supply, use an isolation transformer for safety and use a 60 watt lamp in series with the power cord to limit current during testing.
The circuitry will be SIMILAR to the power supply found on page 9 of schematic you can download at:
http://elektrotanya.com/behringer_ub1204fx_pro.pdf/download.html
Dec 15, 2010 | Behringer XENYX 2442FX Mixer
I am looking for a power connector wiring diagram for the Behringer Eurodesk MX3282A? It was rewired by someone and I think the wire combination is mixed up because when plugged in it seems to blow...
Some of the mixers have common connectors.
It appears that for the three pin connector, pin 2 is center tap of AC source, and pins 1 and 3 are the ends of the transformer windings.
This is from a schematic of a MX2643A which MAY be similar to yours. One of mine has a 3 pin Amphenol connector with a locking screw ring...
Use this info at your own risk, however, the power inout is easy to trace out to verify. They use a typical bridge rectifier to get plus and minus from the external transformer.
The pin markings on the connector CAN be confusing.
Suggest you use the light bulb trick of putting a small lamp in series with the 120 line as an auto reseting fuse.
Mar 03, 2010 | Behringer Music
Just got hold of a Roland R8 but no power supply - any ideas?
Well, you might try:
http://www.yub.com/products/?productID=3190411
The supply has a three pin connector and supplies +10 and -10 volts at unknown current. Don't have a pinout.
I am sure you can cobble something up if you can''t find the ACH120 official power supply.
You would need to find the pinout polarity to connect power if you have to make your own. One would taake unit apart and trace those input wires to something that would define the polarity. First find ground, then look for input filter caps which will tell you the polarity on the pins.
Jan 30, 2010 | Music
Power Supply V-amp 2 Pinout Diagram
Don't have the pin lay out but the power supply is a transformer with two isolated secondaries. The blue & brown leads come from the 20VAC 200mA and the black & white 11VAC @ 800mA windings. I used two doorbell transformers (and a rheostat for the 11VAC section). The reason for two transformers is the secondaries MUST be isolated or something will fry!fb818bb.jpg
Jun 09, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
