Question about Garden
Hard to start, won't stay running, full throttle wavers.
  • 636 Answers
Try playing with the choke
Posted on Jul 25, 2009
How to reset accelerator on a 2012 dodge avanger
Try this. If tps is positioned correctly and idle is correct.
You can recalibrate the throttle yourself to eliminate flat spots or pauses in its response curve.
This should work on most Fly by wire cars, they work on chevy and dodge for a fact
1-ignition to RUN but do not start
2-wait until all the dash warning lights go out (engine light should be the only one to remain on)
3-slowly depress the gas peddle to the floor (take at least 15 seconds to gradually push it to the floor, do not waver as you push)
4-slowly release gas peddle to full up (again, take at least 15 seconds to gradually let it back up, do not waver as you let up)
5-ignition to off
6-DO NOT START IMMEDIATELY! Allow to sit for up to 10 mins+, then start and check for difference in response and linearity.
Sep 07, 2016 | 2012 Dodge Avenger
Rough idle, bogs when I give it throttle then dies
Brad:
Go back to the carburetor adjustment screws and snug them down gently. Do not use force on those screws or you'll damage the needle valve seats. Turn both screws out one and a quarter turns out and start the saw. The motor should stay running.... if not adjust the screws until it stays running. Turn one screw in until you hear the motor start to stall, then turn that screw out just a little bit. turn the other screw in until the saw starts to stall, then turn that screw out a little bit. Now if the saw bogs at full throttle, turn one screw out one quarter turn. See if the saw runs at full throttle... if not turn that same screw in to where it was and try the other screw the same way. If you're good, you can adjust the screw while the saw is running to get the best full throttle run. This is not an exact science, and it takes time and many adjustments to get the saw to idle and run at full throttle. Good luck... and have patience.
Oct 03, 2015 | Garden
Very hard starting and won't run full throttle
try valve clearences check air cleaner and check pilot and main jet again in carby
Jun 19, 2013 | Husqvarna Garden
Engine runs full throttle and won't throttle down
Try grabbing the governor arm coming out of the side of the engine where the throttle linkage comes from, can you manually slow the engine down with that? Is it stuck?
Jun 09, 2013 | Cub Cadet Garden
2004 yfz 450 (ATV)
Remove and clean the carb
May 20, 2013 | ATVs
Only runs full throttle
first I would replace spark plug, I dont know how old your fuel is, but here are different types, some burn hotter, some cooler, but a gallon of that fuel does not stay good over long periods.
Mar 03, 2013 | Traxxas T-maxx 4wd Nitro Monster Truck
Car won't stay running
did you give it a tune up change plugs fuel filter
Feb 17, 2013 | 1987 Oldsmobile Toronado
Won't run full throttle
try and clean the screen inside the muffler
Jul 29, 2012 | Mantis 2-Cycle Gas Mini Tiller/Cultivator
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
WON`T START COLD, STARTS ON STARTING FLUID 96 TRACKER
96 , TRACKER?
IF IT RUNS AND STAYS running. then that means the car is flooding or is in a sad state of tune.
tune it up and it will start every time.
if not ask me here.
http://www.kick-fix.com/
see my guest book. ask a question.
1; tune up
2: bad ECT sensor.
3: stuck closed IAC.
my page answers all sidekick questions.
Feb 04, 2009 | 1992 Geo Tracker
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
