Question about Tablets & eReaders
Every time I opens apps on my tablet it just closed right bk
How do I close the 16 open browser tabs on my 10in digiland tablet? It won't !et me open a new tab bc 16 is the max. I can view them and open them but no option to close any/all.
From the home screen, if you look at the bottom of the screen.. the square which is second from the right should bring up all apps currently and previously used. You should be able to tap the X on the top right of each app box to close them individually. Alternatively, opening a browser window then to the right of the address bar is the amount of open tabs you have.... tapping on the number should bring up the open tabs... give them all a little time to completely load up, then you should be able to close them the same as above.
Hope this helps you solve your problem :)
Dec 01, 2016 | Tablets & eReaders
How do I get my apps to work?
Irulu Tablet - Android Forums at AndroidCentral.com
forums.androidcentral.com/other-tablets/236406-irulu-tablet.html
Dec 18, 2012 - 25 posts - ‎22 authors
I just got my irulu 4.2 Jellybean tablet and this is my first time dealing with ... I know you can't install/use an Android app on a pc but all I want to do is load it onto .... As soon as the irulu tries to open the dl'ed file, it will bring up the ... I just bought my daughter a irulu 7 in tablet and it is driving me crazy she is ...
Jan 01, 2016 | Irulu 7" 4gb Google Android 2.3...
Tablet did not come with play store app and I need it to download an app. How do I add it.
GO to you tube type in your question with your tablet details click search and when Videos pop up chose the following one "CONSUMER DEPOT " and follow the instructions to the letter .This should get playstore on your tablet .
Dec 21, 2015 | Xelio P900A-BK 9" 8 GB Wi-Fi Black Tablet...
Take so much time to charge the battery and while usage battery discharge so early. kindly guide?
I charge my iPad during the night so that it's ready for me in the morning.
With regard to discharge times, this is dependent on the number of Apps you have open and what other service you have running.
When you have finished with an App, press the home button twice and close each of the Apps by swiping upward on the screen. This will close the App completely, until you are ready to use it again.
Also check that Bluetooth is off when you are not using it.(go to Settings - you will find the Bluetooth switch there)
Feb 23, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Ap opens and when I touch play it closes.
delete and reinstall the app. To delete - press and hold the app till it wiggles then press the x on it. It may prompt about deleting app data and that's your call. first time you could say to keep. then reinstall the app and try again.
Nov 20, 2014 | Apple iPad (16 GB) WiFi Tablet PC
When I open FB is closes itself after a few seconds
yep it does that facebook app cause spring board problems and it crashes and pops out of the fb app 2 or 3 times it sometimes take to get it to work, its the facebook catch in the app, app is faster then the down link page.
Aug 22, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Can I download facebook to samsung galaxy tablet?
Not sure Samsung is pressing you ti use one of their apps, for Facebook otherwise you could try to download it from the Samsung App store to from the Google app store.
There is also a way to open a page in your browser, but could become annoying when it closes down every time you exit the browser.
Jul 26, 2014 | Samsung Galaxy Tab 2 Nd Generation 7 8gb...
My apps continuously stop and I have factory reset numerous times to no avail on my apex ap7s118 plz help me with this problem
Hi.. by going to task manager u should have to clear the previous opened apps.. so that apps are running in background.. so u have to close it every app.. or
Update the Definitions for OS.. then the problem will solve..
Apr 06, 2014 | Tablets & eReaders
Manual zte tablet how to close apps and clear history
Menu>settings>applications>manage applications>select applications>ones you tap on selec t applications you will find the option close application and clear history.. :)
Feb 21, 2013 | ZTE V9 Smartpad Android Internet Tablet
Zynga poker iPad app doesn't open
Double tap the home button on your iPad and try closing the app from the row of apps that will appear at the bottom of the screen. Just press and hold the icon until the red x appears, then you will be able to close the app. Once you have closed it, try restarting the app.
If this does not solve the issue, then I would recommend removing the app from your iPad completely and reinstalling the Zynga Poker App.
May 17, 2012 | Apple iPad 32 GB 3G Tablet PC
Tablets & eReaders Logo
48 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
