Question about Tablets & eReaders
Tablet does not have volume button - Tablets & eReaders
Where is the reset button on my RCA Cambio 2-in 1 notebook/tablet
NOTE: Doing this will clear the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the tablet.
To "Hard Reset" the tablet...
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet.
Jan 25, 2018 | Tablets & eReaders
7" Tablet. How do I hard reset my tablet ?
Start with the tablet fully powered off (not just in standby). To force the tablet to a fully off state, hold the power button pressed for until it powers down. This can take 10 to 20 seconds.
Hold the volume up button pressed (some devices may use the volume down button), and then press and hold the power button, until a small menu appears. Release the power button and then the volume button.
Use the volume up/down buttons to select the required menu entry, and then tap the power button to action the selection.
Apr 04, 2015 | Tablets & eReaders
How do I hard reset RCA 10" tablet??
hold down all buttons...power camera volume all of them together
Dec 31, 2014 | Tablets & eReaders
Steps to reset tablet which is stalling up again
hard reset in android tablet PC's
different keys have hard reset in android tablet PC's
u can try like this method
  • volume down + home button + power button
  • volume down + power button
  • volume up + menu + power button
  • volume up + power button
  • volume up + cam +power
  • volume up + lock button + power
Hope this helps !
Dec 19, 2014 | Tablets & eReaders
Forgot password how can I rest my tablet
1) Power off your tablet.
2) Press and hold Volume Down and Power buttons.
3) When The Samsung Galaxy logo appears, let go of the Power button and continue holding Volume Down button. Two Android icons appear.
4) When the two Android icons appear release the Volume Down button, then press the Volume Down button to move the cursor to the left; and then press the Volume Up button to make your selection. The Android system recovery menu appears.
5) Press the Volume Up or Down button to select "wipe data/factory reset", and then press the Power button to make your selection.
6) Press the Volume Up or Down button to select "Yes - delete all user data", and then press the Power button to make your selection.
7) When the reset is complete, press the volume Up or Down button to select "reboot system now", and then press the Power button to make your selection.
Sep 27, 2014 | Samsung Galaxy Tab 101 Tablet...
I put a password on my android tablet and now i dont remember the password
Make sure you backup your files by connecting it to a PC (if you have access to one) via USB cable,you will have to do a hard reset, otherwise there is no other way to get past the lockscreen (unless you have a recovery option with your email address)
Below is the process to tell you how you can hard reset your Samsung tablet (should work with any tablet):
  • Ensure that the Samsung tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
  • Once your device is hard reset and rebooted successfully, you will see that the unlock pattern obstruction is also gone, and you can now set a new unlock pattern on your Samsung tablet.
Oct 21, 2013 | Tablets & eReaders
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet.
Aug 24, 2013 | Acer ICONIA Tab W500PC52G03iss
How to reset my hkc tablet
For and HKC 7" tablet there is no reset button however you can follow these steps to reset it first you power the device off completely next you hold down the power and volume up button simultaneously until the words HKC touch the wonderful world appears then you will release the power button only you will then find an android on its back you may release volume button then you will tap android or press power button to open the menu you use volume keys to scroll and power button to select scroll until you find wipe completely select that
Apr 03, 2013 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Tablets & eReaders Logo
41 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
