Question about Cub Cadet Garden
New cub cadet was running great shut off cane back no power
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
retort
SOURCE: cub cadet weed eater wont stay running
air vent in gas cap pluged, push a pin through it
Posted on May 28, 2009
SOURCE: the pto on my cub cadet 1515 cuts off. It will
Mine does the same thing. I've found that normally this is a heat-related problem and by removing all the clippings from the deck the blades will re-engage just fine until (unless) the clippings mount up again. Hope this helps; I make sure the deck is clean top and bottom before I mow.
Posted on Sep 23, 2009
  • 78 Answers
SOURCE: cub cadet has no power changed battery still no
Blown fuse. There is a fuse somewhere thats blown. It will be about a 15 amp in a fuse holder either back by the battery or behind the dash. U didnt specifiy the 100 number If thats a starter-gen it could be a reg- relay issue.
Posted on Oct 22, 2009
BAMOUT
  • 2478 Answers
SOURCE: need wiring diagram for cub cadet lawn mower lt1045
Posted on Mar 15, 2012
Why would my belt on my cub cadet 1046 mower keep popping off?
Did you put all the belt keepers back on? I find a lot of DIYers usually leave one off thinking it is not important.
Jun 30, 2015 | Cub Cadet Garden
Dar n PTO Clutch
Most likely low tension. first, double and triple check the routing of the belt against the manual. then make sure you have the correct belt.
May 04, 2014 | Cub Cadet Garden
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet shuts down, oil full but blinking light, runs like a champ til then
oil light says on for about 2 hrs from when it due to be serviced by the hr metre not when you have serviced
Apr 08, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet mower LT1042 will not start. It acts like it wants to, and you can really smell gas too. Has a new battery, starter, and spark plug.
Just had the same problem with our LT1042 and it was the fuel shut off soloniod. Could not buy just that piece so we took it off and cut off the piece that went up on the carborator and put it back on. Started right up. Now it back-fires when we shut it off but it runs.
Mar 31, 2010 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
44 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
