Question about Garden
Greenfield Ride on Mower need to increase tension on drive belts
    New Friend:
  • 124 Answers
As a rule there is 2 ways.
1 is a spring loaded idler pulley and the other is to loosen the motor and pull it back.
Depends on the age.
Posted on May 14, 2017
I want to change the drive belt on my ride on mower the Brand is greenfield ride on mower
If you have not got a manual you can go to website to get a full blown spare parts manual with prices try that
Feb 03, 2018 | Garden
My Greenfield 12-30 mower constantly drops the Drive Belt. How do I correct this?
First make sure that you have the correct size belt.
Then make sure the belt you are using is not stretched or worn out. Check all pulleys and make sure they are not worn and that they are in alignment. Finally make sure that all the idler springs are in place. It is wither an alignment issue or a belt tension issue
Feb 02, 2015 | Garden
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
May 19, 2014 | Craftsman Garden
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
I need a diagrahm of a belt drive greenfield ride on mower
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Nov 10, 2010 | Garden
Cutting deck on greenfield evolution mower will not disengage
Usually this is caused by badly worn belt or incorrect type of belt fitted, check allignment, tension, belt size should be marked as A... not 13A..... if marked as the latter it is an "automotive" type belt not suited to "slipping" when belt loosened to disengage cutter. Check also for the belt has not rolled over in the groove.
Oct 31, 2009 | Greenfield Industries Disston #752980 Mm...
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Jul 18, 2009 | Garden
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
