Question about Hardware & Accessories
I have a 3280 Melnor water timer. My Question is when first setting say for every two day cycle when is the first watering First day or the Second day?
5 Suggested Answers
  • 175 Answers
SOURCE: Won't pump out water at the end of wash or rinse cycle.
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: Can it be set to water every other day
Assuming that your model number is 3018 you just need to keep cycling through the frequency options by pressing "change". The hourly options end with "h" and the day options end with "d". So "2d" means every other day. Press "accept" when you come to "2d".
Posted on May 30, 2009
manhandy
  • 146 Answers
SOURCE: Can't correct the current time in the Melnor 6
go to there web Site
Posted on Jul 13, 2009
  • 396 Answers
SOURCE: I need a new O ring for the battery compartment
just go to the garden center at local home improvment store
Posted on Oct 25, 2009
The brand new timer just installed is leaking profusly from the connector to the faucet...?
turn water off at the main then put Teflon tape on threads then re attach..................problem should be solved
Apr 18, 2016 | Melnor 3280 Digital Aqua Timer Watering...
How to fix a melnor 4 zone digital timer with stuck valves?
bleed the air out of each valve then re tighten bleed screw. if still stuck open then buy new diaphrams
Dec 13, 2015 | Melnor 3280 Digital Aqua Timer Watering...
LEAKING AT INPUT
Get some teflon tape and wrap threads then re attach hose
Jun 23, 2015 | Melnor 3280 Digital Aqua Timer Watering...
I need instructions of Melnor 304F timer for watering
From the Melnor 304f actual instructions:
Use 9V alkaline batter only! Flashing lighs indicate that the battery is low and needs to be replaced.
1) To start: Turn Dial to Off position and press ENTER
2) Set Time: set the current time and press ENTER
3) Start Time: set the time to start the first irrigation cycle and press ENTER.
4) Frequency: Set the frequency of the irrigation cycle e.g. twice a day = 12h and press entere.
5) Duration: Set the duration of the first irrigation cycle and press ENTER.
-- to change the duration
Turn the dial to the new duration and press ENTER
--to turn the water on manually
Turn dial to ON position.. The water will turn off automatically after 30 minutes.
-- to turn the water OFF
Turn the dial to the OFF position
Do NOT press ENTER when dial is in OFF position, otherwise the unit will clear the program, and you have to Reprogram the unit following the steps 2 through 5.
Jun 29, 2014 | Flotec Garden
Melnor 4 zone aqua timer dosent follow program
Water timers and Melnor timers last a year or two. They come with 1 year warranty for defects in workmanship.
Change batteries, reset timer if there is a reset protocol, buy another timer. Melnor, Orbit, are major brands. Gardena is not supported. Yardworks repackages other brands.
Copy following link for all watering and irrigation timers on market, with links to manuals for each brand:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add a comment and say what you find.
Jun 20, 2013 | Aqua Hardware & Accessories
Verve Digital Water Timer as sold at B&Q have lost the operating instructions.
Verve water timers might be Melnor:
Open following link for manuals.
http://www.melnor.com/instructions.php
Links to other water timer manufactures and manuals are found on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Jun 14, 2011 | GARDENA Water Timer
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
May 29, 2009 | Aqua Hardware & Accessories
Hardware & Accessories Logo
48 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
