Question about Food Mixers
My mixer isn t turning on - Food Mixers
Sparking at brushes
This isn't abnormal although cleaning the armature with fine emery or sandpaper can help.BTW, new brushes will always need a period of run-in before their contact with the armature has reached its best.
Nov 27, 2011 | Food Mixers
The mixer simply doesn't turn on. Worked fine yesterday. Today it seems like it's just dead
HI.Let me jusk ask if yiou also tried to connet to another socket.Let me just clarify that the motor itself did not work /rotate as well.Prior to that situation,have you tried to mix more than what is the capacity of your mixer.If possible motor was overworked/that's why its coil was burnt.There. are possibilities then. First might be that the mixers terminals inside will no longer engaged properly that's why it opens the circuit.Second the motor isn't working because the rotor and armatures coil was burnt because it runs beyond its maximum wattage capacity that's why it draws much current beyond the rotors coil capacity.Did you mixed something heavy.the motor works heavier the last time you used the unit?
Jul 23, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My classic KA mixer will not start on speed position one or two. It will start if I move the the speed knob to 3 or 4. I then can use any speed. This isn't normally a problem unless I forget and start...
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 08, 2011 | KitchenAid K45SS Classic Stand Mixer
Model K5SS -- The speed control lever will not stay in the slowest position - STIR - but will pop over to the next position - 2. Can I adjust anything to fix this problem?
Open up the Motor Housing and inspect the Switch Lever with Stud.
The Lower Gearcase has many depressions which allow the stud to
snap into it when the Speed Selection lever is moved. If the Stud
is worn out then there isn't much you can do but replacing it.
3184193 is the Switch Lever And Stud part number for your model.
Jul 03, 2011 | KitchenAid K5SS Heavy Duty Commercial...
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
Hi! my mixer is about over 10 years old , its making a sqeeking like kind a noise and its spains i think a bit to fast , could you tell me what do you think is the problem
I had your same issue with the speeds. I think you need to adjust the speed through the speed control panel.
Open the back spherical cover on the Kitchenaid KSM90, the area with one screw on the top. You should see the speed control panel, a black and gold square connected to wires. There should be three large silver screws - two on the top, left and right - and one on the bottom. If you turn the top two screws clock wise the machine slows down at lower speeds. When you adjust the bottom screw, the higher speeds are effected. This process is called "tuning" and you can find an online video how-to through sites like Youtube.
As for the squeaking, you maybe replace some of the grease inside of the machine. Food grade gear lube would do if you are up for the challenge, but kitchenaid also sells a grease for their stand mixers for a pricey $20. It isn't hard to put in new grease and clean out the old but requires a lot of disassembly.
~ I am not an expert but a hobbyist. This advice is only my opinion based on limited experience. ~
May 26, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Beater hits side of bowl
There may be a few problems that are occurring here. However, in the past I have seen that the bowl has become misshapen after repeated use and normal wear and tear. Some times if the bowl isn't too bent you can re shape it by rolling it on the floor or a counter. Hope this helps!!
Thanks. Grant
Feb 20, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Hello, I have a KA mixer like the one above. The knob that controls the speed will not move. What can I do to make it work??? Mary Jane and thank you.....
Hi MARY JANE. To answer your question you first need to find out why your speed control knob is stuck? That will require going “under the hood” to determine the root cause of your control knob’s obstinacy.
Most likely something associated with the control knob & lever has either come loose or broken inside your mixer to lock it into its current position.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the first file K45SSWH0.pdf (341.41 KB) listed under Parts List (1) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled: “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts. You’ll want to focus on part #s 2, 3, 4, 5, and 6, which is our speed control assembly. Check to see if something isn’t blocking you’re the movement of #3. You should be able to determine if something has broken. If something has broken, you can order replacement parts and install yourself.
Here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping.
Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are links to three excellent websites that detail the disassembling/reassembly of a KA mixer that may be helpful for you.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, and feel comfortable doing it.
I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Feb 24, 2010 | KitchenAid K45SS Classic Stand Mixer
Speed control lever stuck or locked. How do I unlock it?
Hi BROOKLYNX. To answer you primary question, no there is no special speed control knob lock that you?ve inadvertently triggered. OK, so without a lock why?s your speed control knob stuck? It most likely that something broken inside your mixer to lock it into position. I wouldn?t continue to operate your machine as you are doing. It?s not good for the electric motor, the electric cord or the plug. It would be better to determine the root cause of your control knob?s obstinacy. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try K45SSW, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts. You?ll want to focus on part #s 2, 3, 4, 5, and 6, which is our speed control assembly. Check to see if something isn?t blocking you?re the movement of #3. You should be able to determine if something has broken. If something has broken, you can order replacement parts and install yourself. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html Good luck and have fun. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid K45SS Classic Stand Mixer
The speed lever does not move
Hi, JJBSKISAIL. From the symptom you described it appears that the speed control assembly linkage has jammed inside your mixer head, for what ever reason. Most likely something’s broken inside your mixer to lock it into position. It would be better to determine the root cause of your speed control knob’s obstinacy.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to ensure it matches your mixer model.
Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. You’ll want to focus on part #s 2, 3, 4, 5, and 6, which is the speed control assembly. Check to see if something isn’t blocking the movement of #3. You should be able to determine if something has broken. If something has broken, you can order replacement parts and install them yourself.
While your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Nov 20, 2009 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
46 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
