Question about Garden
1983 20R engine fuel line diagram show and tell on the line where the gas line on the gas tank
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
rycgl
  • 1545 Answers
SOURCE: Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Posted on Jun 01, 2010
  • 4088 Answers
SOURCE: I Need Diagram of Fuel Line Hookups For a Poulan
The line at the rear of the fuel tank with the fuel filter is the main feed line to the carburetor and connects to the upper nipple. The lower nipple on the carburetor goes to one of the primer ports, and the other primer port goes back to the tank, which has no filter on the tank end. On the primer port, it is cut and try--remove the tank return connection and leave loose. Place the main fuel line on to one of the primer ports and try to pump fuel into it with several pumps.Make sure the filter in the tank is not plugged. If nothing, shift the line to the other port of the primer and try pumping again. When successful, remove the main fuel line and return it to the upper carburetor port. Run a new line from the lower carburetor port to the active primer port and try to pump fuel again. If it won't pump fuel, reverse the two connections at the carburetor and try to pump again. If still nothing, there is trouble within the carburetor which should be cleaned with spray carburetor cleaner and maybe re-kitted. When you can finally pump fuel through the carburetor, then attach the tank return line to the open port on the primer bulb. Hope fully, the engine should run at this point. Hope this helps!
Posted on Jun 19, 2010
panilling9
  • 284 Answers
SOURCE: Which fuel line "port/inlet" on the Walbro wt-380
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Posted on Jun 25, 2010
SOURCE: Diagram on gas tank and lines and how they hook up
I have 5 lines on the gas tank counting the petcock can you tell me were they all go
Posted on Jul 28, 2011
Where are the purge lines to the purge valve diagram
Hello! Here is the diagram you requested...#5 is the Pressure Control Valve (Purge Valve)...
(1)Throttle Body (2)EVAP Solenoid Valve (3)EVAP Vacuum Switch (4)EVAP Canister (5)EVAP Pressure Control Valve (6)Floating Roll-Over Valve (7)Fuel Tank
Guru.Saailer
Jan 01, 2012 | 1996 Buick Roadmaster
I need a diagram of the fuel line from the engine to the tank on my 1994 dodge dakota, so i can find a gas leak
There is no such diagram available. You will simply have to follow the fuel lines from the fuel rail on the engine along the truck frame rail towards the tank, or from the fuel tank along the truck frame rail towards the fuel rail on the engine. Some are on the left side frame rail and some are on the right side frame rail, depending on which engine your vehicle is equipped with. You simply have to LOOK.
Sep 05, 2011 | Dodge Dakota Cars & Trucks
I need a routing map of the fuel lines for the wildthing 2375
There is no diagram that shows this, however i can tell you where they go, the fuel hose from the tank with the fuel filter on goes to the fuel inlet on the carb, the nozzel nearest to the pump side of the carb ( cover held with one screw ) the pipe from the carb nearest to the metering side ( cover held with four screws ) goes to the suction side of the primer ( short nozzel on primer ) there is then a pipe from the pressure side of the primer ( longest nozzel on the primer ) back to the tank ( just pushed into the top of the tank ), just remenber the primer pulls fuel from the carb, and dumps it back into the tank.
Mar 02, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I am replacing all the fuel line including primer bulb on a craftsman mini tiller/cultivator. is there a drawing or diagram to show which line goes where?
I see that this machine has a 2 stroke engine. These directions work on the 2-stroke engines of Sears trimmers. I've never seen a diagram but many explanations are out there.
The small diameter line out of fuel tank (has fuel filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carburetor. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Oct 21, 2010 | Craftsman Gas Mini - Tiller/Edger
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
Gas line leak. looking for a diagram of how gas lines are run
The Lines are simple if it's a 2.4 EFI the lines run on the driver side inner rail from the center top of fuel tank, and up the middle of the firewall to the injector rail or throttle body carburetor there is also one line that runs from the evap canister back to the tank and to the fuel system three lines total one is a return line the large line is the main fuel line and has the fuel filter mounted on it and is under the driver side door inside the frame rail.
Jun 24, 2009 | 1995 Nissan Pickup
1995 geo prizm gas tank replacement
what is the unit called on top of gas tank where both fuel lines come into the fuel pump?
Oct 06, 2008 | 1995 Geo Prizm
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
