Question about Samsung ML 4551NDR - printer - B/W - laser
PRINTER NOT PRINTING ERROR MESSAGE : OPEN HEAT ERROR CYCLE POWER
    Sergeant:
  • Samsung Expert
  • 406 Answers
This is the problem of the fuser unit. You may get it repaired/changed . Also you may approach Authorised servic ecenter.
Posted on Jul 27, 2009
Error message
low heat does not allows u to print , wrong error
May 07, 2014 | Samsung SCX4826FN AllInOne Laser Printer
How to cycle the power on a Samsung CP610ND?
Pull out the plug, wait five minutes, replace plug and switch on.
Jan 07, 2014 | Samsung CLP-610ND Color Network Laser...
79 Service error
79.XXXX PRINTER ERROR
  1. Turn off the printer.
  2. Turn on the printer.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. (If the message only appears with a certain software program or print job, contact the software vendor for assistance.)
If the message persists, try the following:
  1. Cycle power.
  2. Reseat or replace the interface cable and cycle power.
  3. Remove the DIMMs one at a time and cycle power.
  4. Try using the parallel interface, if possible.
  5. With the EIO cards removed from the printer perform a cold reset:
    1. Remove any accessory, including the HP Jetdirect card.
    2. Turn off the printer.
    3. Hold down the GO button while turning on the printer.
    4. When the printer displays COLD RESET, release the GO button.
Aug 30, 2012 | HP LaserJet Pro 400 M401DN Laser Printer
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Feb 07, 2011 | Kodak ESP 5 Printer
Printer error 3515
Kodak ESP-5 error message 3515....tried Kodak way but didn't work....could hear the print head attempt to move but couldn't...unplugged unit from power....opened to expose the print cartridges...removed small screws on sides and back of printer...gently pry open top....turn gears on right side with finger toward front several turns.....check and see if print head will now move to center....(I removed cartridges and print head so I could see the blotter under print head move to back position. Re-installed print head and cartridges.) plugged power cord back in and turned on...unit cycled and then screen showed normal....replaced screws in top panel.....printed test page...back in operation......Don't be heavy handed....plastic will break very easy I think when opening panel if not careful...
Dec 28, 2010 | Kodak ESP 5 Printer
"Low Heat Error Cycle Power" message. Faxes won't print.
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Apr 06, 2010 | Samsung SCX-5530FN All-In-One Laser...
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Error message
OPEN TOP COVER CLEAN ALL RUBBER PAPER FEED WHEELS WITH RUBBING ALCOHOL APPLIED TO A MICROFIBER TOWEL.
THEN LOOK AT CARRIGE BAR THE BIG SILVER BAR THAT INK CARTRIDGES RIDE ON APPLY TWO OR THREE DROPS OF 3 IN 1 OIL AND TOP THE TOP OF IT AND RESTART PRINTER
Jan 17, 2008 | Epson Stylus Photo R340 InkJet Printer
Samsung ML 4551NDR - printer - B/W - laser Logo
528 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
