Where on my house do i install my sc610 antenna
Is it possible to replace the antenna on my Motorola fr60?
These antennas are not made with replaceable antennas.
Mar 04, 2015 | Motorola Radio Communications
Can I install an external antenna to this TV?
it is located next to the power plug and if you have more than one tv in the house you will need to use a splitter
Oct 16, 2013 | Sony KLV-S23A10 23 in. LCD HDTV
Moved into house, used auto tune feature on analogue tv get poor reception on everything bar two channels, bought DTV, autotune gave same result, with no digital channels picked up at all. Obviously an...
Yes its antenna problem?maybe your house too closed signal your antenna is getting hard to find signal for your TV.
You must use a Outdoor Antenna to widen your signal range.
And also i suggest that you move you antenna outside your house or at your roof to be able to enhance the signal for your TV.
Hope my solution will help.
Jul 03, 2011 | Computers & Internet
Just bought a house and moved in. I have plug the TV into the wall antenna socket and the TV comes up with the message 'weak or no signal' what could be the problem?
Hi, congratulation on your new house!
The problem is obviously from your antenna. The TV is not recieving any reception from the antenna and that is why it is displaying 'weak or no signal'.
Cross check your antenna connection and make sure the antenna wire is intact.
Also, most antenna's come with a booster. The booster makes reception from the antenna very strong and the TV would be clear.
Lastly, is this a new antenna or were you using it in your old house?
Please give me a feed back.
Yours sincerely.
Elect_Comp.
May 12, 2011 | Televison & Video
How do I install the power antenna? I have a replacement, and the wiring is there, but I don't see how to mount the part.
PLEASE DON'T FORGET TO RATE!!!!
Removal & Installation
  1. Lower the antenna and remove the luggage compartment trim panel.
  2. Disconnect the lead-in cable from the antenna and ground strap.
  3. Disconnect the antenna motor wires at the connectors and disconnect the control box connectors.
  4. Remove the top mounting nut and stanchion assembly.
  5. Remove the two nuts retaining the antenna bracket assembly to the quarter panel.
  6. Remove the antenna assembly from the vehicle.
Some antennas require a special socket to remove the locknut
Once its loose the nut can be removed by hand. Sometimes it can be twisted off with a needle nose pliers, but that usually ruins the tool
The antenna mounts in the luggage compartment against the support member
The motor and housing sit on a stand that is bolted to the support member
Unplug the antenna lead from the staff tube
Unplug the connector to the motor
Unplug the connector to the relay
Its easier to remove the antennae from the support to gain access to the ground strap screws
To install:
NOTE Correct sequencing for installation is important to prevent water leakage or dimpling of the quarter panel
  1. Connect the antenna cable, power connector and control box connector.
  2. Insert the antenna mast through the quarter panel hole and position bracket on mounting studs in the luggage compartment.
  3. Install the stanchion assembly.
  4. Loosely install the two bracket retaining nuts.
  5. Install the top-mounting nut.
  6. Tighten the bracket retaining nuts.
  7. Install the ground strap.
Nov 19, 2009 | 1990 Lincoln Continental
Converter box installation. Not a clue.
rf cables will work fine for older tvs. newer tvs should use the composite (yellow, red and white cable) to produce a digital picture and sound. FYI the indoor antenna works best when positioned in a window. Best thing to do is install an outdoor antenna in the attic near the gable vent or on the exterior of the house.
Jul 04, 2009 | Televison & Video
Grundig YB400PE broken antenna
Unfortunately, your description of the problem means that your radio must be taken apart to be fixed. Replacement antennas can be found purchased. It would require installing the new antenna and most likely soldering it to the broken wire. Do you have a picture?
Apr 05, 2009 | Grundig YB 400PE AM/FM/SW Radio
Installation of vt holden commodore aerial rope and mast
You access the ariel via the left hand wheel arch.
1. Remove left wheel mud guard. It is held in with a bunch of press studs which can be difficult to remove. I found pulling on the plastic mud guard whilst turning the screw helped.
2. unbolt the electric ariel assembly. There is an earth strap that needs to be unscrewed as well.
You should be able to get the ariel out far enough to work on it.
3. Remove chrome plated nut to top end of mast tube.
4. With great anger and force, remove the dead ariel and drive cable from the mast.
It's difficult to get the mast to work unless it's earthed properly.
5. Get you hand inside the wall and remove the ariel face plate. Swear if you have to.
6. Put the ariel mast assembly back into the wall and hook it all up minus the new ariel.
7. Switch your radio on, then put the new ariel into the mast. Gears facing the rear of the car. Switch the radio off, it should retract. If not you may need to push it in a little further.
8. Remove the ariel mast again and slip the chrome nut to top end of mast tube and tighten securely.
9. Ask the spouse to close up whilst you have a beer.
Apr 03, 2008 | Car Audio & Video
Pay tv cable
you may bypass the box by using a straight connector, find the cable that lead to the TV room and connect it to the cable from the aerial antenna.
Mar 06, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
