Error 092 319. Replaced magenta. Same error. - Office Equipment & Supplies
5 Suggested Answers
  • 95 Answers
SOURCE: Ricoh CL7100 - Toner Cartridge Error
Not one answer for this problem. It could be the tube going from toner cart to developer unit is clogged or kinked. It could be the dev unit. Get a toner vac and remove toner and black cap and spring and using the round hose end create seal and vac the tube. The part that goes into the toner cart has hole on the very end, it might have broke off (look at another color to verify). The worst case is the toner attraction pump has failed. One fix is shake the toner and reinstall.
Posted on Mar 11, 2009
POCBM
  • 121 Answers
SOURCE: hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Posted on Apr 02, 2009
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
  • 8 Answers
SOURCE: Error 10.90.02
I have had a similar problem with my printer, It turns out that the aftermarket toners that I was using were using a sort of re-certified circuit board. When the chip embedded to the toner is not new some times it can not be read by the machine correctly.
Also have your pulled the cartridge and put it back in again? It is possible that the chip on the toner is not making proper contact with the printer.
Posted on May 23, 2011
How do i fix error code C7103
you need to replace the magenta developer unit
Sep 03, 2015 | Kyocera Taskalfa 250ci Color Copier...
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
I get an error sc361 and sc364
sc 361 Magenta TD sensor (pcu)
sc 364 Black TD sensor (pcu)
check if the pcu's are in position tight
May 08, 2009 | Ricoh CL4000DN Laser Printer
Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
Apr 01, 2009 | HP Color LaserJet 2600n Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
96 people viewed this question
k24674
jasbo
jasbo
