Question about Vanguard Heating & Cooling
Vanguard vent free propane gas heater model: VP2800BT..I need to replace ODS Pilot/assembly..Old part was #098245-01..Is #120630-02 the replacement I need?
SOURCE: Comfort Glow Vent-free Gas Heater CGN18B
Check with Ebay seller s.a.w.inc for available thermocouples. If that doesn't solve the problem the valve unit will likely need replaced.
Posted on Feb 13, 2009
  • 582 Answers
SOURCE: My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Posted on Aug 11, 2009
Testimonial: "Thank you for the clear/thorough advice. Not only did you clarify the problem, but your suggestions on how to fix it were very useful too. "
SOURCE: wont stay lit
If the pilot flame does not touch the thermocouple, the heater will do exactly what you describe.
Get a short piece of copper tubing that will fit snugly over the thermocouple and bend the short piece so that it is in the pilot flame.
Posted on Oct 02, 2009
  • 236 Answers
SOURCE: need parts: pilot assembly and thermocouple
THe thermocouple either has 2 wires or a coppr tube going to the gas valve. They can be bought at a good hardware store or a plumbing supply. The length of the wires or copper tube will be the determining factor as to which one you need. As these thermocouples, when heated generate a small electric charge tha keeps the gas valve open. Should cost no more than $10-15 USD
Posted on Oct 10, 2009
  • 17 Answers
SOURCE: Pilot on logs won't stay lit
Hold pilot button longer. if this doesn't work your Thermopile has gone bad and will not generate enough Millivolts to keep gas valve pilot open. A new thermopile will generate 750 millivolts. It cost less than $20 dollars but is difficult to replace. You should call a certified technician. They will charge you about $100.00
Posted on Oct 27, 2009
I have a Vanguard wall heater model VN18TB that will not stay lit and the electric igniter won't work
The ignitor is battery operated. Remove the button and replace the AAA battery wit the (+) going INTO the body (-) against the button.
The heater has a pilot with an Oxygen Depletion Sensing (ODS) safety shutoff system. The ODS/pilot is a required feature for vent-free room heaters. The ODS/pilot shuts off the heater if there is not enough fresh air. If the heater will not stay lit with plenty of fresh air available - this may be faulting. Likewise, a mispositioned thermocouple will not sense a flame and fail, too.
A link to the heater manual is below:
https://www.allpartsinc.com/mmALLPARTS/Others/VN18B.PDF
Feb 13, 2014 | Vanguard Heating & Cooling
3rd thermacoupler in 1.5 months. I can get the pilot to light and heat a tank, but it will not recycle. Once the tank is hot the pilot goes out. Obviously not the thermacoupler unles strange odds that 2...
Your DESA/Vanguard Vent-free, Blue Flame Heater has a pilot assembly that is equipped with and Oxygen Depletion Sensor (ODS) . When this becomes clogged with dust, lint, spider web, etc, the pilot may light and burn for a few minutes, but will soon shut down. As the ODS senses that there is not enough oxygen for safe combustion. This mimics a faulty thermocouple. A good indication that the pilot is dirty, is when the pilot flame curls upward and looses contact with the thermocouple. Cleaning the pilot and it's ODS with canned air and a straw nozzle (like you clean your compute with) should solve the problem.
To further help you, I have included a link to the Owner's Manual for your Model, as well as a link to how to clean the pilot & ODS
http://www.desatech.com/manuals/Vent-Free%20Heaters/107884-01.pdf
Cleaning the burner & pilot demo: http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
I hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Desa International GWN30T 30,000BTU NatGas...
Pilot light too big, how do we adjust pilot light on a Vanguard KV1800?
There is no adjustment for a Pilot Flame's Length on a Vent-free Gas Appliance. However, if you're using Natural Gas and it's a Natural Gas Heater, the normal length of the pilot flame is 2 to 2 1/2".
If it's a Propane Gas Heater and the pilot flame is as long as previously stated, you probably have a pressure problem from your tank. Contact your Propane provider to have them check the pressure on their tank regulator.
Jan 31, 2011 | Vanguard Heating & Cooling
The Pilot will not light.There is gas coming through slowly
Start with cleaning the Pilot ODS assembly.
Try this link for general instructions:
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Thanks
Oct 06, 2010 | Vanguard International Blue Flame - Large...
Change from natural gas to propane
You could do it but it would be very expensive. You would need to change the ODS pilot and the gas valve itself. I am not sure even then it would work correctly. These are not conversion ready.
Jul 26, 2010 | Vanguard International Blue Flame - Large...
The flame in weak and it heater will not light
You need to replace the ODS pilot assembly.A low pilot flame will not allow sufficient heat to generate proper voltage to hold valve
Nov 13, 2009 | Vanguard International Infra Red - Large...
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
IGNITOR DOESN'T IGNITE
clean out the pilot assembly with a can of compressed air.Check for any loose or freyed wires and tighten or repair. Can't help you on replaceent parts.
Nov 21, 2008 | Desa International Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top Vanguard Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
