Question about Canon Office Equipment & Supplies
I have a canon mx492 all in one printer and I need to know how to set my fax for incoming calls
  • 317 Answers
SOURCE: receiving incoming faxes
# Press the button to enter Fax mode. # Press
. # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Posted on Aug 07, 2007
  • 1447 Answers
SOURCE: Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Posted on Feb 22, 2008
  • 121 Answers
SOURCE: How do I keep my fax machine from picking up incoming calls ?
Try This:
Hope it helps
Posted on Mar 14, 2009
  • 121 Answers
SOURCE: Brother MFC-7420 doesn't receive faxes - send out is OK
The machine should be in TAD mode:
Look at this page 4-1:
Hope this helps
Posted on Mar 15, 2009
SOURCE: Can I set a Canon 1023 IF Imagerunner to a "Manual" FAX setting?
restore default settings on ir1023if
Posted on Sep 30, 2009
Distinct ring function for fax?
Setting The Receive Mode
  1. Press <FAX>, then press <Menu>.
  2. Press <OK>.
  3. Use [<]or [>] to select the receive mode.
  4. Press <OK>.
Aug 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Sir, O/G FAX goes but i/C Fax not coomes Please
Have you pressed the button to enable incoming faxes on the keyboard of the printer? The button should have a light next to it so that when incoming faxes are enabled you know about it. Once you press that button the printer will allow them to come through.
You also need to confirm the settings in the printer under the fax catagory and choose the number of rings before the fax machine should pick up a call and whether an incoming fax should have a different ring tone than a regular phone call ect.
You can access these choices by using the software installed in your pc under settings. Or you can press the menu key on your printer and use the up and down arrows to scroll the features and press enter or ok when you find the one that you are looking for.
There should be two catagories for fax choices. One is usually called fax and the other fax - advanced ect. Try checking the features available in both to make sure all of your options are set that way that you want them to be.
You can also try press the start button when an incoming fax is on the line. This will manually start the printer to accept a fax that is trying to come through.
Sep 14, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
Can.t displayed incoming call
restore it as factory setting or replace control pannel cable
Jul 27, 2010 | Canon FAX B155 InkJet Printer
How do I set fax and phone on one incoming line?
You can't do that automatically on one line unless you ask for distinctive ring from yyour phone provider. Dist. ring gives one pattern for fax and a different ring for regular calls. Otherwise the fax needs to be set to manual and you answer each call and press fax start when you hear fax tones.
Oct 16, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Can not recieve incoming faxs
You can download the manual from Canon.
My incomming fax doesn't work either.
Mar 18, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Cannot receive auto faxes
This is a known problem with the MX850 - Canon thinks it works, but it needs to be FAX Only when you're out of the office and TEL PRIORITY when you're in the office - then you hit "Hook" when you hear an incoming call as a fax tone. It's a manual answer machine when in TELEPHONE Priority
Mar 18, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon MX310 just set up - phone rings like incoming fax
check out the connection some where loose or also check out connecting the external phone line to the printer and whether the same problem occurs or not.
Dec 05, 2008 | Canon PIXMA MX310 All-In-One Printer
Do Not buy Canon Copiers
What kind of Canon did you buy? What model? Who installed the copier and set up your network. Did you buy it from a Canon dealer. Also, dose the the copier ahave a fax PCB. I install Canons all the time and they run perfectly. It's only my oppion, I've been working on them for 18 years... It seems you bought one that did not have all the options loaded or you got a non-industrial model.
Nov 10, 2008 | Office Equipment & Supplies
Fax/tel mode
Go to the following link
Click on Support and Service Tab
Enter -- answering machine -- into search and click search
Click -- Fax Machine is answering all incoming calls
Click -- Setting the Fax Receive Mode
Observe -- Ans Machine Mode
Dec 23, 2007 | Canon PIXMA MP530 All-In-One InkJet...
old marine
old marine
