Need registration pin for video - Computers & Internet
I need the activation code and my application code is 00093025 and registration code is 42a517
POSTING PIN NUMBERS AND REGISTRATION CODES WILL BE DETRIMENTAL TO YOUR SECURITY!!! CALL YOUR CELL PROVIDER BEFORE OTHER PEOPLE FIGURE OUT HOW TO STEAL YOUR CODES!!!
Apr 10, 2015 | Cell Phones
Binatone 1910 flashing not registered to base
Registration:
Instructions if you need to register handsets to the base:
You can register additional handsets to have up to five handsets per base unit, with each handset's number (1 to 5) shown on its display.
1. Press and hold <PAGE> on the base station for more than five seconds to put the base station into registration mode. (Note: there is no feedback to know it is in reg mode.) It will stay in registration mode for about 1 minute. So complete following sequence within this time. (It helps if handset is kept very near to the base during this).
2. Press <MENU> and <UP/DOWN> on the handset to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING. If the handset registration is successful, you will hear a confirmation tone and the <antenna icon> will stop flashing. This may take a short while. The handset will automatically be allocated the next available handset number. This handset number is shown in the handset display in standby mode. If thehandset registration is unsuccessful, the <antenna icon> will still flash and the display will return to ' REGISTER', so you will need to repeat registration process.
Mar 24, 2014 | Binatone Lifestyle 1910 Twin Cordless...
Mixcraft registration code
i need to buy a registration ID and code can you sell me one
Jan 04, 2014 | Mixcraft 6 Home Recording Studio Music...
How to fix nokia n73 sim card registration failed
this is what happened to my 5230 before..suggest u try to contact ur service provider to check ur sim registration details.normally,registration failed when u type a wrong pin code more than 3 times..or try to reset ur phone by press *#7370#...gud luck..
Oct 21, 2012 | Cell Phones
This game only install with registration key.but idont have it
You need the registration key as evidence you bought the game legally and therefore can install it. You cant install the game without the registration key. If you have lost it, the only solution is trying to contact the game makers with proof of purchase. Hoping that they give you another registration number.
Mar 01, 2011 | Video Game Consoles & Games
I have a Eurotel E1110 device but it is asking me to register the third phone again. I do not know the pin-number so what can I do?
7.5 Registration
If you have a multi-handset system, you already have more than one handset
registered to your base unit.
with each handset's number (1 to ) shown on its display. (Note: each handset
1. Press and hold <PAGE> on the base station for more than five seconds, to
put the base station into registration mode. It will stay in registration mode
To register a new handset to your base:
for about 1 minute, so the following handset sequence must be completed
with in this time.
2. Press <MENU> and <UP/DOWN> to select REGISTRATION.
handset registration is unsuccessful, the <antenna icon> will still flash.
I Used 0000 As the default pin when asked.
Hope this helps you
Jun 11, 2010 | Lands Phones
Can't register new handsets
with in this time.
Hope this helps you
Apr 10, 2009 | Lands Phones
Bought phone from china need to unlock
contact service provider and reset sin pin info they will have a long number for you to put into the phone that will reset the sim pin back to default.that should fix your proiblem.
Feb 18, 2009 | Cell Phones
Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Feb 02, 2008 | Siemens Gigaset 2415 Cordless Phone
Computers & Internet Logo
David Payne
David Payne
