Question about Pioneer Televison & Video
I have a Pioneer Laser disc player CLD V850 and I need a new laser lens optical pickup. but can't seem to find one or the part number for this . Does anyone have one or know where i can get one.?
SOURCE: used lens laser lens cleaner & now player won't play.
Hi Mollins, did you ever resolved your DVD player issues. I have the same problem and I dont know what to do.
Posted on Mar 14, 2007
  • 50 Answers
SOURCE: Problem after installing new Lens for LG DVD Player !!
I've been working on DVD players since they were invented, and was factory trained by Sony, Hitachi, and Kenwood, but I must admit, I'm not understanding your question.
The laser diode fires through a lense, that is supended on tiny wires, and moved into focus by an electro-magnet. Now, I have replaced lenses that have popped off due to poor adhesive from the factory, but I have no idea what you mean by "unlocking the lense"
If you mean that you have replaced the entire laser ***'y, and it is not emitting, then that is likely because the shorting bar has not been removed. It protects the laser during shipping and storage, and must be removed. If you compare it to the old laser, you will see pins shorted together by a tiny metal bar, or in some cases just solder...if this is not removed, the laser will not emitt. If you put the old one in and it does, then 99% that is the problem...if the old one does not, then the laser is probably not your problem. Hope this helps, and be careful to always look at the laser at an angle to check for red light, so you aren't performing home laser eye surgery...not a good idea!
P.S. After re-reading your question, on some models, it is possible to replace the lense ***'y, because the electro-magnet has failed in some way, and does not move the lense, but if that is the case, I don't know why the laser would suddenly stop emitting, just because that was changed...normally it is all one ***'y. Good Luck!
Posted on Mar 14, 2008
  • 1512 Answers
SOURCE: Pioneer PD4500 Single-Compact Disc Player 1.
Hi norberty
When you load a disk, do you hear a faint screaching sound, or the disc turn a tiny bit, but wont sart to spin? If that is what happens, then the spindle motor is lazy. You will need to replace it. Sometimes, you can get the motor to work again, by squirting some crc2-26 lubricant spray into the motor(through the bottom) Be careful not to use too much. Try this, if it doesnt sort it out, let me know here before you rate the solution, We can go further
Posted on May 08, 2008
SOURCE: laser disc player produces b&w only lately? pioneer cld-d504
Ooops, in my efforts to find laser disc INFO I ended up in a completely irrelevant category; because there no longer exists a Laser Disc category. So I shall abandon the laser disc player as technologically obsolete (there goes still another species of dinosaur off to the fossil beds) and give up on seeing those movies in color.
Posted on Nov 09, 2008
  • 567 Answers
SOURCE: Cd player doesn't work
you need service manual i got one from ebay with all manuals and service manuals for 5.00 a typical manual will cost you 28.00 best search ebay for nsm manual
Posted on May 08, 2010
I have a Pioneer LaserDisc, model cld-v850, where the the ejection button would not close the disc inserter. It only closes half way. Any help is much appreciated, thank you!
Unplug pc, open cabinet and look for dust and debris , clean with compressed air.
If it's still dirty use 50/50 distilled water and alcohol with a swab. Allow 30 minutes before plugging back in.
Dec 10, 2014 | Pioneer Televison & Video
My pioneer blu ray player displays " no disc " message when insert any disc , Can you pls advice the chance of problem
The most likely problem is a bad optical pickup(the lens is part of that) aka laser. If the laser is weak, it can't read the disk, hence the error "no disk". For more information, or should you have further questions, please visit my website at You may contact me through the website. Thank you.
Jan 07, 2013 | Pioneer home theater system XV-BD707 User...
Coby TF-DVD 8503 will not turn on, if on video skips and turns off
Optical pickup unit might be faulty. Try by cleaning the optical lens, by inserting a lens cleaning disc into the player and play ti at least 2 times. If this do not belp you; optical pickup unit [Laser reading unit] should be replaced.
Jun 05, 2012 | Coby Televison & Video
Player not reading disc , what could it be
Just clean the laser pickup unit lens, by inserting a disc cleaning disc. this disc an be bought from most of the electronics spare part selling shops at your town. If it doesn't help you, there is no other way than replacing its Laser Pickup Unit with same type and number. OK.
Jan 15, 2012 | Pioneer PD-F507 25-Disc CD Changer
When I insert myDVD disc, the screen shows loading for a minute or so--then reads incorrect disc and bad on the player. This is a disc I have used before and has the label that shows it is the disc this...
It seems that optical laser block gets fail to read data on disc and possible cause could be dirty/ clogged lens or optical laser block failure.
Put lens cleaning disc in unit to clean optical lens and check DVD playback, if that does not solve the issue then optical laser block would be defective and requires replacement that would cost approx new player price.
Hope these info will help.
Jun 29, 2011 | Toshiba SD-K220S DVD/CD Player w/Built-in...
How do you use a NEXXTECH Laser Lens Cleaner?
The NexxTech Laser Lens Cleaner uses six super-soft brushes to ensure thorough and reliable cleaning, without harming the delicate optical components of your disks. Enjoy your DVDs more and improve your music archive by cleaning your optics in your CD or DVD ROM. The easy-to-use audio instructions walk you through the cleaning process from start to finish. This laser lens cleaner process will prolong the life of your disc player, improve visual clarity and sound quality. Features
  • Works on CD, DVD, Blu-ray - all optical drives
  • The six brush system cleans off the entire laser lens
  • Will not damage sensitive optical components
  • Includes easy-to-use audio instructions
How to Clean the Laser Pickup Lens on your DVD Player X missing_author_image.png eHow Electronics Editor This article was created by a professional writer and edited by experienced copy editors, both qualified members of the Demand Media Studios community. All articles go through an editorial process that includes subject matter guidelines, plagiarism review, fact-checking, and other steps in an effort to provide reliable information. By an eHow Contributor
Is your DVD player malfunctioning? If you're getting a no-disc error, you may need to clean the DVD player's laser pickup. The laser pickup is what reads DVD's and allows you to view them on your TV. If you need to clean the laser pickup lens on a DVD player, follow these simple steps.
Difficulty: Moderate Instructions things you'll need:
  • Isopropyl alcohol
  • DVD lens cleaner
    • 1 Make sure the laser pickup lens is actually the problem. There are a wide variety of reasons that a DVD player might not read a disc efficiently. The disc could be scratched or dirty, for example. Test the DVD player with a disc that you know works before trying to clean the lens.
    • 2 Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
    • 3 Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens.
    • 4 Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection.
    • 5 Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab.
    • 6 Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process.
May 05, 2011 | Televison & Video
I have a Pioneer PD-M550 6-Disc changer. When I try to play a disc, it won't spin... UNLESS I turn the unit upside-down. Then it plays just fine. So the lens is fine, but something is keeping it from...
Hi. You need to replace the opu (optical pickup unt), laser in other words. The laser diode is slowly getting weaker and the lens works in conjuntion with the laser. The reason it works when it's upside down is because gravity is pulling the lens closer to the disc, thus it does not need as much power to focus onto the tracks etched into the disc. Replace opu with type PEA1030 aka PU-23 Hope this helps you out and good luck.
Mar 08, 2011 | Pioneer PD-M603 6-Disc CD Changer
I have a Pioneer cld-v860 with an error code ho. can you tell me what it is?
Pioneer CLD-V860 is an old model laser disc player and you need to have service manual copy to get error code details as we do not have related service manual copy.
Required service manual copy can be downloaded from HERE for small fee and service manual has all technical info about this unit, schematics, troubleshooting chart, part numbers etc.
Hope this info will help you.
Sep 21, 2010 | Audio Players & Recorders
When I put in a CD or DVD on my Polaroid PDM-0743 star loading but after a while have a error. DAD DISC or NO DISC, any ideas what should be the prolem?
If cleaning the lens on the laser does not solve the problem, then you will need a new laser or optical pickup. You may as well buy a new unit.
Aug 02, 2009 | Polaroid PDM-0743 Portable DVD Player
Laser disc player produces b&w only lately? pioneer cld-d504
Nov 08, 2008 | Pioneer Computers & Internet
Televison & Video Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
