Question about Samsung Televison & Video
How do I setup an indoor antenna to an Samsung dtv2798 digital tv?
  • Samsung Master
  • 2,342 Answers
Attach it to cable connector
Posted on May 14, 2017
How do we set up the tv to pick up air channels with the indoor amplified antenna?
Terk FDTV2A HDTV Indoor Antenna Unboxing Setup Test Part 1
double check your TV is set to the correct input before scanning.
the link above shows installation
press the helpful button
Jan 22, 2016 | Sharp LC52E77UN 52 in TV
I got a rca home theater older model TV....how do I program it to receive digital channels using and indoor rca HD antenna
Let's assume this is a digital TV, not one of the old analog home theaters. First hook up the antenna. Then go into the TV's setup menu. These vary by model in their choices and the names they use. Find the section of the menu that deals with "input" or "home." You're looking for a choice of "cable" and "antenna." Choose "antenna." There will also be a selection that tells the TV to "scan" for channels. That's what you want it to do. Typically this takes anywhere from 30 seconds to a couple of minutes. Once the TV has found all the channels available, you can exit the menu. From then on it's a simple matter of using your remote to choose the input you want to watch at that time: TV (from the antenna); Cable (if you have a box plugged into another input); DVD etc.
A note on antennas: indoor ones tend to have VERY limited range. They will get reliable reception only on local stations with high-power transmitters. My brother lives in Maine, miles away from the nearest tower, and his indoor got just one station consistently, but with lots of dropouts. A $35 outdoor one got four, three of which were reliable. He bought a better one for about $90 and now he gets 7 or 8, all but one of them consistently.
May 23, 2014 | Audio Players & Recorders
How to get rca indoor antenna to pick up free digital channels on my Samsung television
Indoor antennas are not very good if you live far away from the TV transmitter. Antenna aim has to be more precise than before with analog TV's. If you can put up an outside antenna you'll probably get them all.
Mar 18, 2013 | RCA Ant121 Indoor Passive Antenna
New rca indoor antenna 1080i and cant get anything on tv , anybody that can help walk me hough it?
Well I just did this last night.
Its funny how everybody forgets to explain the basic tehnical stuff like setup and channel scaning.
We did not get any channels at first. but because I read internet a lot before on the subject, I knew that I had to do "channel scan".
ok first go to setup.. you have things on your tv changer or .. on the tv itself on the side back of it.
We have a new tv. Flat tv. if yuou have an old one you might have to get the digital exchanger thing that somebody mentioned previously.
If you do have flat newer tv..
first set up the tv to respond to antenna.
as the source.
then.. I had something that said.. digital off , and also antenna off. I had to change that to .. whatever other choice came up first.. and there were a lot of choices, like cc1 cc2 t1 t2 and so on.
I changed it to c1 or cc1 something like that.. on analog. that got us few channels. then I changed the digital one also to something.
I still have to tinker with it.. but we had only few channels and they are clear.
Jul 21, 2012 | Televison & Video
How do I turn on the digital tuner? Samsung
Hi my name is Roety,
I can help you with your issue ,
The digital tuner is always on, you just need to run the autoprogram in the setup menu with a digital signal connected.
An antenna is ant or air signal
using Cable click cable when scanning in channels.
If using a cable box there is no need to scan channels.
if using an indoor antenna it may not pickup any (roof antenna is better)
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
I tried connecting an RCA antenna to get digital stations, but the tv didn't recognize any of the digital stations on the scan. Any ideas?
its very difficult to get digital stations if youre using an indoor standard antenna , unless you have a SPECIAL DIGITAL ANTENNA for indoors , but I suggest an outdoor antenna , the higher ,the better to locate digital stations , AJ
Nov 30, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Can this tv pick up the new digital off air signals? i just bought an indoor digital antenna and no channels will come in. do i need a converter box?
You need a digital box. If the TV is connected to the Digital Box & you have it setup correctly you should be able to get Digital channels. An internal antenna is not the best idea unless you are in a good reception area.
Oct 21, 2009 | RCA TruFlat 27F520T 27" TV
Cannot access setup!!
make sure you are in the tv mode first or you will not be able to access the setup mode and make sure you run setup
Sep 22, 2009 | RCA L37WD12 37 in. LCD HDTV
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Televison & Video Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
