Question about GPS
Touch screen stopped working!
Unit reloads to warning screen then freezes up no matter how many times screen is touched. Resetting the unit does nothing!
  • shameer ahamed
    shameer ahamed May 11, 2010
    This we cannot conclude as the problem is only with the touch screen, it may be because of the process hang. So you better try to reset the device and give a try.
    Scholar:
  • 105 Answers
Do you have a warranty on it ? If it doesn't have any physical damage the company should replace it for you or repair it .
Posted on Jul 25, 2009
When I turn my sony reader on the touch screen will not work, i can not get my book to reload. i was in the middle of reading and jsut froze. i tried recharging and still nothing.
Have you tried resetting your device (reset button is very small on the bottom - use a paperclip end or pen tip to reset it)? I had to do that, and it took a bit to reload, but was up and working fine after that. Be sure that your device is charged prior to resetting and disconnected from your computer.
Sep 02, 2011 | Sony Reader Touch PRS-600
The vibrate setting has stopped working. Vibrate doesn't work at all. Is there a way I can fix it?
Please try resetting the phone but this will reset all the settings to factory default.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. Unlock the screen by touching Lock or pressing the Unlock Key on the left side of phone, then touch Menu to access the menu .
  2. Touch the Settings & Tools icon.
  3. Touch Phone Settings.
  4. Touch Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Touch Reset Default.
  7. Touch OK after reading the warning message.
  8. Touch Revert. A confirmation message is displayed briefly before the phone resets itself.
source: http://www.resetcellphone.com/solution/LG/vx9700-dare
Feb 22, 2011 | LG Dare VX9700 Cell Phone
Screen touch is not working properly.how can be solve this problem? htc p3450
Possible fault of touch screen or the software. to make sure that the display is not due to moisture use a good dyer to warm off and reset, remove clean and set back the unit.
If none of these works then the software can be reloadded or else the touch screen is faulty.
Sep 24, 2010 | HTC Touch P3450 Smartphone
The touch screen is not working. After resetting
If the buttons on the touch-panel LCD screen do not respond correctly or do not work at all, adjust the LCD screen calibration. Consult the instruction manual if specific information is required to perform this procedure.
NOTE: The touch-panel LCD screen cannot be calibrated if it is rotated.
Aug 08, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
IPhone touch screen freezes and stopped working
hold down the home and power button together, should reset the iPhone and stop this happening. (you will not lose any data)
Aug 04, 2009 | Apple iPhone Smartphone
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
Ipod touch repeats a song over & over I have to manually advance
linda if you have not upgraded your ipod`s firmware please do it because i was facing the same problem,i upgraded the firmware and it fixed the problem.you can upgrade the firmware using itunes and clicking on check for firmware.if the firmware is already upto date then please reload the same firmware.
take care.
Jun 13, 2009 | Apple iPod touch
Vm9512 touch screen stop working just like that
The backlight has gone bad. I have seen this exact problem in SEVERAL other Jensen units.. The backlight might last 5 years, or in extreme cases, maybe 15 minutes.. I have also seen them bad out of the box.
Dec 19, 2008 | Jensen VM9510 Car DVD Player
Keypad malfunction
You need to try and calibrate the screen. Turn on the unit and keep your finger on the power button. After 30-40 seconds the calibration screen will come on, release the power button and follow the instruction of touching the while dot as it moves around the screen. Once thisw is done your touch screen should work.
Jun 03, 2008 | Garmin StreetPilot C330 GPS Receiver
Freezes at pin request
Can you enter the PIN number? Is the touch screen working? Many times a unit will appear to freeze when the problem is the touch scfreen. You need the PIN number and a working touch screen in order to get back into the Garmin and restore to default.
Nov 20, 2007 | Garmin StreetPilot c510 Deluxe GPS...
GPS Logo
175 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
