Question about Sewing Machines
Where do I position the 3 threads once they are in position....
Serger is not stitching
... not quite sure what you mean by "not stitching", here are a few things to check. If the problem is more specific, please leave me a note with more details.
Let's start right from the beginning (for 4-thread overlock/serge):
1. According to the serger manual, ensure that the proper needles are being used. That they are inserted all the way up into their positions and that the flat side of the needle is facing away from you. The left needle will appear to be shorter that the right, that is OK, all is going perfectly.
2. Use four good quality spool of serger thread (good quality sewing thread is fine also) and place them on the spool or cone holders. There should be "little bucket looking things" that fit onto the cone pins to make the cones sit nice and straight, use them. Rattling thread will cause grief.
3. The first thread to be loaded onto the serger is the Upper Looper ...it is the big needle looking thing that swings left to right and back again above the sewing surface. Follow all the threading guided according to your manual, the threading guides are generally coded in a colour specific for this looper. Once the eye of the Upper Looper is threaded, place the thread under the presser foot and to the left. Presser foot down.
4. Next is the Lower Looper, the big needle looking thing that swings left to right and back again under the sewing surface. It can be a bit tricky in some sergers as the thread need to pass to the left and then back to the right under the sewing surface. Your manual should have a good diagram if you can not follow the threading guides on the serger itself. Again the threading guides are generally colour coded with a different colour but specific for the Lower Looper. Once the looper is threaded, it is important that the thread is placed directly OVER the Upper Looper as it comes out of the eye of the Lower Looper. Place the thread now under the presser foot and to the left. Presser foot down.
5. Thread the right needle front to back and place the thread under the presser foot and to the left. Presser foot down.
6 Thread the left needle front to back and place the thread under the presser foot and to the left. Presser foot down.
7. Hold the four thread ends firmly in the left hand and give each thread individually a good pull down over the serger and behind, this will ensure that the threads are all engaged in the tension dials.
8. Set the tensions to the middle number, although this may vary with the brand and model of your serger. If you have the manual check for the correct settings specific to your unit.
9. Set differential to 'normal', or '0' (if your unit has one)
10. Set stitch length to about 2 1/2 to 3.
11. Make sure that the blade is in cutting position. We can trouble shoot blade position later if needed.
12. Make sure that you have the overlocking plate installed ... not the rolled hem plate (if your serger has two plates). Some sergers use the same plate for both functions.
13. Using two layers of medium weight fabric do a test stitch, what is the result? Is a chain forming? Are there stitches on the fabric? Are they looking the way they should?
Hopefully this has helped you, please let me know.
Cheers.
Sep 01, 2014 | Sewing Machines
I cannot thread the machine. Specifically, I cannot get thread through the part that almost pops up when theflywheel is turned. How can I get thread through that? I also need a refreshed on threading the...
make sure the flywheel has been turned to where the needle is in it's highest position. Take the thread through #1 (machine should be labeled) and that should be a metal "notch" that holds the thread underneath to guide you down to #2 and if I'm not mistaken the thread guide for #3 is where you are having trouble. If your needle is in its highest position, then the metal guide inside the machine slot will also be at its highest position. Just take the thread back up, pull it back towards the back of the machine straight up and down in a 90 degree angle. When you pull the thread back, it should go through the slot opening. Once you have pulled it all the way back it should catch on to the metal mechanism in that slot. Then you pull the thread back down and continue on with steps 4 and 5 (threading), just look for the numbers on the machine...
Aug 04, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Top thread will not pick up bobbin thread
Your bobbin is not installed correctly.There should be an excess thread coming out of the bobbin. Second-the thread wheel is the other way around,it should be positioned to follow where the extra hair of thread is to be going.And once you insert it in you'll notice a snap and the bobbin is settled firmly and locked into the shaft.
Oct 31, 2010 | Singer CG550 Mechanical Sewing Machine
Machine is not pulling the bobbin thread
1. Put in a new needle, make sure the flat side is facing the rear of the machine.
2. Take the thread off the top of your machine. Rethread the top of the machine, with the presser foot in the up position. Make sure you thread the take up lever. The take up lever is the lever that disappears and then reappears near the top left of the machine. The thread goes to that lever after the tension unit.
3. Put your tension dial on 5 or 6
4. Make sure your bobbin case it threaded properly, when you pull on the thread once it's up through the hole in the needle plate, you should feel "slight" resistance.
5. When you turn the Hand wheel on the side of the machine, turn it only towards you, never towards the rear of the machine. Try to pick up the bobbin thread now, if it still doesn't work, you need to take it to a service tech.
Oct 17, 2009 | Husqvarna Sewing Machines
Bottom thread on sewing is looping
when I was taking sewing classes, this would happen every now and then to one of the class members, including me. My teacher told me that the looping on the bottom thread is generally caused by the machine being incorrectly threaded on top, which therefore wont let the bottom thread go into the stitch properly and causing it to loop.
We were told to basically follow these suggestions in order to reduce chances of this recurring & to date, I still refer back to it when I forget myself, especially if I have been off my machine for a few weeks.
1) Machine should be clean and free of lint within machine and in and around bobbin casing.
2) Correct and sharp needles correctly inserted.
3) Threads will generally feed better from the vertical position so a vertical thread stand/ attachment is recommended.
4) Before beginning to thread the machine, check that the pressure foot is in the up position, the feed dogs are engaged, the thread take up lever is in the uppermost position.
5) As you begin to thread ensure that the thread is fully engaged into the tension disks.
6)Once machine is threaded and both threads are visible (i.e the lower thread has been brought up from the bottom), slowly sew a few test stitches on a scrap piece of the fabric you intend to sew, to ensure your tension is correct. This saves time as you havent sewn a length of fabric only to find all of the bottom thread looped (experienced in that one!!)
7) If all this fails, it could be a timing issue of when your needle thread is contacting with the bobbin thread, which only a service person can fix for you, sorry.
Hope this helps you, or someone out there.
Oct 04, 2009 | Bernina Artista 180
Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Feb 20, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Singer touch and sew 648
Thread the machine as if you were going to sew. When you thread the needle, pull the thread off to the left and wrap it around the thumb screw on the left and just above the needle. Wrap it only 2 or 3 times and hold the end of the thread. With bobbin in place and the face plate slid open, push the thumb lever on the left under the face plate to the left. Begin to 'sew'. As you do, the bobbin will wind and the thread you are holding will detach. Once the bobbin is full to the outside line, slide the face plate the closed position. As it closes, it will release the thumb lever. Put the needle in the slightly lowered position and slide something blunt under the pressure foot pulling thread from both the bobbin and the needle; cut the thread when you've pulled it out sufficiently.
Jan 19, 2009 | Sewing Machines
Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Jul 19, 2007 | Brother XL-3510 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
