Question about Kubota Garden
Kubota GR2110 speed change pedal is loose and lawn mower starts but pedal does not engage forward or reverse!
SOURCE: Changing blades on Huskee LT4200 Riding Lawn Mower
wd 40 is a luberecant,, blaster is a penterant ,,works much better, been using blaster sence 1960....
Bill
Posted on Apr 25, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 11 Answers
SOURCE: Honda HTR3009 riding mower runs great but won't
sounds like your drive belt is slipping.
look under your engine (you may have to raise the cover to engine to do this), see if the belt that is around the pully which is on your engine drive shaft is on correctly or is in need of replacing.
Posted on Jun 24, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
I have a Kubota G6200 hst lawn tractor. Mowing the other day and it started sputtering. Then the forward/reverse pedal quit working.It starts great. just will not move.
Obviously you have an issue with the drive to the rear wheels.. Need to check the transmission of power from the motor and see where it stops. Could the the tranny or shifting mechanism at fault
If there is a belt drive check for a good belt or one that has not stretched and slipped off its pulley.
Aug 22, 2016 | Kubota Garden
Why isn't something engaging when accelerator pressed?
It would help to know more information about the mower in question. Walk behind push mower? walk behind self-propelled mower/ Riding lawn mower? Lawn tractor? Or goat...just kidding...lol. The engine horse -power or cc's and make of the mower and engine. Anything happen before the problem or was it straight out of storage. Does the gas pedal feel normal? Could you be talking about the forward/ reverse pedal? These types don't engage by depressing them, they engage by releasing the pedal.
I'm going to guess you have a riding lawn mower or lawn tractor. The pedal for those types of mowers controls the transaxle ( rear wheels, transmission and differential basically). If the pedal move properly and it was working ok when it was stored, then check to see if you can push it with little effort. On most transaxles there is a disconnect rod to disengage the transaxle for towing the mower without damaging it. Pulled out for disengaged and in for engage. If that all checks out it could be very low on transmission fluid or the drive belt might be off or broken depending on which type you have. If it is low on fluid, you have a leak. Hope this helps.
Mar 11, 2016 | Garden
Kubota T1570 transmission will not engage in forward or reverse. Starts fine and runs fine, mower blades engage, but no movement. Worked yesterday, not working today. Any ideas? Thank you.
Only problems that come to mind are rather obvious ones. My first guess would be a broken HST belt- the one from the engine to transmission- OR part of that belt assembly (idler pulley, slipped off a pulley, broken tension spring). Another possibility would be the pedal linkage. Maybe a pin fell out of that somewhere and the linkage isn't engaging the transmission.
Oct 27, 2013 | Kubota Garden
Transmission will not engage.
The transmission belt is probably loose or the clutch is faulty.
Apr 29, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Jul 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
The drive pedal is stuck forward and wont budge along with the brake pedal...
Drop mower deck and have a look.
Both rods run to the rear on the right side.
Possibly something interfering.
Jun 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
127 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
