Question about Kenmore Dryers
I have a Kenmore Elite dryer that runs for 7 seconds then cuts off. It won't restart until 5 minutes then does it again, run for 7 seconds then stops. Any suggestions? I have cleaned the vent lines.
    Sergeant:
  • 246 Answers
Sounds like a motor going out on overload or high temperature.
Posted on May 14, 2017
Testimonial: "It is not the motor and I've replaced the high limit fuse as well as the thermo fuse"
A Whirlpool Duet dryer, purchased new 11 yrs ago. Turn it on it runs for 5 minutes & stops. Sometimes have to wait a few minutes before it restarts. Any suggestions as to what the problem is?
Hello Jacquie Burgess,
Thermal cut off triggered - Part number 279973
(you MUST verify part number).
Sadly... I went out onto my favorite site looking for High-temp
cut-off or thermal limiters (ELECTRONIC)... but "APPLIANCEPARTSPROS" failed to RE-CONFIRM their very OWN number they gave out... wp697772
A direct call FROM YOU would be appropriate...
BETTER STILL... would be YOUR OWN part number from your
owner's manual...
However... the are MECHANICAL reasons your dryer may actually be reaching OVER-TEMPERATURE situations...
and your machine could be correctly shutting down for SAFETY REASONS:
TWO Principal reasons would be
- A BLOCKED dryer vent (usually lint)
- A Broken/Defective Blower
To check AIR-FLOW... You outside dryer vent should be putting out a POWERFUL stream of hot air..
If you do NOT feel that powerful air flow... disconnect the vent behind your machine and check it again there...
If there is a difference you HOUSE DUCT needs to be clean
(do this regularly to prevent FIRE DANGER).
Then...
IF no powerful air flow is felt directly behind your machine... your BLOWER IS DEFECTIVE (see below)
I had a similar issue on my Kenmore Elite (turned out to be a blocked VENT (BIRD: inside the MACHINE).
Else your HIGH-TEMP LIMITER is DEFECTIVE and needs replacing (possibly... WP3391914, (you MUST verify)).
Hope this helps.
PLEASE SEE... the video
http://www.appliancepartspros.com/whirlpool-wheel-blower-wp697772-ap6010627.html
http://www.appliancepartspros.com/whirlpool-thermal-cut-off-279973-ap3094323.html#autoplay
Whirlpool WP697772 Blower Wheel AppliancePartsPros com
Aug 11, 2016 | Whirlpool Dryers
Kenmore Elite Oasis dryer model #110.67032600
It sounds like you may need to replace the timer.
Apr 20, 2014 | Dryers
Kenmore elite stackable starts and after 30 seconds stops then after 2 minutes starts again with a huming sound
Your talking about the dryer right? If so, the blower is not working. Unit has "high temp" safeties built in to shut dryer off if overstepped. No blower to force air over heated coils, causes high temp causing unit to cease working until cooled down then it will start and stop again after another 30 sec.
Nov 11, 2013 | Frigidaire Kenmore Washer Tub to Pump Hose...
Dryer keeps cutting off and has to be restarted.
There is normally a switch inside the motor that detects in turning at speed. That keeps the dryer running until it is either stopped, the door is opened, or the cycle is through. I am guessing that the contacts are getting bad on this switch.
Jan 03, 2012 | Dryers
I have a kenmore dry that seems to hum very load once it heats up. If you turn it off and rest for 30 minutes it will sound fine again until it is 15 minutes into the cycle. What would be the likely...
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
GENE
Sep 12, 2011 | Kenmore 84072 Electric Dryer
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
We have a Kenmore Elite gas clothes dryer (110.73952101). It will not completely dry large loads. We have to reset timer and restart the dryer. If we set timer for 40 minutes, dryer may run for 10 minutes...
Loads may be too large. Also when you reset and restart, the heat overload is cutting out. If your discarge is kinked or not venting properly this will cause it not to dry as well. Also check your lint screen. Good Luck!
Apr 13, 2009 | Dryers
Kenmore Elite Oasis Steam dryer runs but gets a F 40 code and stops. Just plugged it in to do my first load. Tried pulling out and checking lint in vent. It seemed to over heat the first time then sat a...
After just now calling the service center it seems that unplugging the machine for 30 seconds or so will reset the control panel. The F 40 code means the signal wasn't working in the machine and resetting it solved the problem. Kind of like when you have to unplug the computer sometimes.
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer
hi nikid,
Welcome to fixya.com
Huuum at your service,
Did you try to reboot or reset the system as we call it?
Pull the plug, OR throw the breaker off , either for 5 minutes and then restart it.
This will usually reset the error codes and get you back running .
let me know hoe you make out?
See if that fixes the problem by resetting the system.
Bess You Huum
please do mopt forget to leave a rating.
Sep 21, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
