Question about Shakespeare Sport & Outdoor - Others
Anti reverse spring on a shakespeare 2640g - Shakespeare Sport & Outdoor - Others
3 Suggested Answers
  • 10 Answers
SOURCE: problem with anti-reverse
if it is a multiplier reel most of the lever tension springs are the same. they can be bought from QUENTIN MILLMAN in portsmouth. they have a mail order branch and can be located on line.i have tried making my own springs but the dog leg has to be at the right angle.best buy the right one for a few pounds. regards barry.
Posted on Sep 29, 2009
  • 3940 Answers
SOURCE: need owners manual for Shakespeare E-Z cast reel
You can find it here
Posted on Nov 03, 2011
Where do i find a switch for a shakespeare 606 trolling motor ....the forward and reverse switch
We have no parts connections here, best bet is to find a boat shop near you and ask them for help getting the part you need.
Aug 18, 2016 | Shakespeare Boating
What is the lever at the back of a spinning reel for?Its located at the back on top
The lever on the back of spinning reels is an anti reverse lock. It is used to prevent the reel from being able to wind backwards or for allowing it to depending on the position it's in.
Jul 26, 2010 | Shakespeare Agility Spinning Reel 6825
I have a Shakespear Tiger model TSP50A. I cannot set the on/off so that the handle ends up going both ways. I inspected the gears and suspect a manufacturing defect. I have had it for over 3 years but used...
Remove the spool, you'll find a little screw by a hex nut, remove the little screw then you can remove the hex nut. by removing this nut you will be able to remove the whole bail assembly. There you'll find the workings of the on/off leaver. There is a fine spring that raps around a brass piece that looks like a washer, looking at it from the side you'll see a grove in it, that is where the spring goes then to the leaver of the on/off control. This spring hardly has any spring to it so don't think it needs a replacement. If the spring is in place check to be sure that the knob isn't striped. Just take the little screw off that holds it in place and inspect it. I hope this helps!
Jun 17, 2010 | Shakespeare Agility Spinning Reels
I have a shakespear alpha fishing reel which rotates both ways and deoes not lock
The switch is the on/off anti reverse switch. It is the switch (probably the only one) on the reel at the base. When the reel is in the upright position, look at the bottom/rear area. That little level controls the reverse. Good fishing...
Nov 14, 2009 | Shakespeare Surf Fishing Rod and Reel...
Need to know were the long spring on my sons spider man rod and reel goes
The long spring (only one in the reel) goes under the bail arm plate. To get it back in, remove the plastic cover plate on the side that pickes up the line (has a line roller on that side). The spring will fit over a small metal or plastic post and rest in a cavity at the bottom.
Screw the cover back on and you're good to go!
Best of luck
Mike
Sep 26, 2009 | Shakespeare Surf Fishing Rod and Reel...
Problem with anti-reverse
Sep 21, 2009 | Sport & Outdoor - Others
Shakespeare 2660 coarse fishing reel,cant remove spool cover
According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
Mar 17, 2009 | Shakespeare Agility Spinning Reel 6825
Sport & Outdoor - Others Logo
37 people viewed this question
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
