Question about Magic Chef Kitchen Ranges
Need a magic chef 38hn-2cx on - wire diagram - Magic Chef Kitchen Ranges
SOURCE: Kneading Blade for Magic Chef CBM 250-2
I found a compatible belt!!! It's a Dayco # 15260, which you can order from partstore.com!!
Posted on Nov 25, 2008
  • 204 Answers
SOURCE: Drive belt needed for Magic Chef CBM 250 Breadmaker
http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Posted on Jan 11, 2009
  • 4 Answers
SOURCE: i need a wiring diagram for a magic chef furnace
There should bee a wiring diagram on the inside door of the unit, it will show fan speed connections
Posted on Nov 01, 2009
  • 7 Answers
SOURCE: magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Posted on Mar 04, 2010
heatman101
  • 43501 Answers
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Posted on Sep 30, 2010
WIRING DIAGRAM FOR MAGIC CHEF MODEL HMCF5W2
Contact Magic Chef directly to request the wiring diagram.
Jun 17, 2017 | Magic Chef Microwave Ovens
Magic chef model 38hn-2cx need a wire diagram for the oven circute
For a wiring diagram, contact Magic Chef directly.
May 02, 2017 | Magic Chef Ovens
What does F3 warning sign mean?
F3 is for a faulty temp sensor. Here is the part to order and there is a video on that same page to show you how to make the repair.
Jun 20, 2013 | Magic Chef Ovens
Magic Chef oven 38HN-3TXW clock assembly 7601P180-60. The clock works and can be set, etc. The relays contacts were corroded so I replaced the relays. The oven elements come on if I short across the relay...
Hi John.
I am sorry but the service manual for this model is not available. I hope that the following can help a bit.
Parts for 38HN-3TXW are listed at appliancespartspro (here the link). As you know parts for the control panel are not available.
Parts for similar models are available. I would contact them to find out if parts from models like 38HN-6TVW-SC are compatible.
Here diagram of 38HN 6TV control panel, it is similar to 38HN 3TX, shown at partselect.com (that shows parts as discontinued).
Here a list of models from 38HN series.
A way to troubleshoot without service manual is running continuity tests between contacts at switch, relay board, control module and elements to understand how wiring is connected and to test wiring. In a second stage the job consists in reading voltage at relay board and timer contacts. Because of the safety issues involved, testing with power on must be done by a trained person.
Where possible do continuity tests. About the corroded contacts at relay board check if there is continuity between the solder joints at the back of the board and the relay connectors (continuity means contact closed with zero Ohms or low impedance). The test is done with power not connected.
Jan 04, 2012 | Magic Chef Kitchen Ranges
Mod# CGS3760ADW
Go to searspartsdirect.com and type in the model number you provided. Your wiring diagram is listed along with all the parts illustrations and information. If you require further assistance, please let me know. I hope this helps you.
Nov 02, 2009 | Magic Chef 31000 Gas Kitchen Range
I need a wiring diagram for a magic chef furnace
Nov 01, 2009 | Heating & Cooling
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
NEED A WIRING DIAGRAM FOR REFRIGERATOR MODEL NO. CTB1521AR
did you look on the back of the ref, a lot of the magic chefs had the wiring diagram on the back of the ref
if not go to www.whirlpool .com and see if you can locate it there
May 27, 2008 | Magic Chef Refrigerators
Kitchen Ranges Logo
27 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
